TBI dumping fuel
Old Oct 18, 2015 | 05:26 PM
Poncho92's Avatar
TBI dumping fuel
I got a 92 bird with 305 rebuilt the motor just dropped in, rebuilt the TBI and now when I turn the key it don't spray it dumps fuel literally. So is there something I missed on wiring or on the rebuild of the stock TBI
Old Oct 18, 2015 | 07:31 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: TBI dumping fuel
Is it one injector or both. My guess would be a torn 0-ring or a ruptured diaphragm.
Old Oct 18, 2015 | 08:07 PM
Poncho92's Avatar
Both of them are, the diaphram is fine from what I can see
Old Oct 18, 2015 | 09:22 PM
2012sergen11's Avatar
Car: 1987 Trans Am
+1 on torn or bad o-rings my tbi truck did the same thing when I tried reusing the 20 yr old ones
Old Oct 19, 2015 | 04:09 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Either way, your going to need to rebuild your FPR. 99.9% chance it's going to be something wrong in your FPR
Edit: It should probably be called injector pod not FPR sorry
Old Oct 19, 2015 | 07:13 PM
Poncho92's Avatar
Got the problem fixed it was the rubber O ring just below the screen. The kit I was given was short the two screens and the two O rings that sealed them now to the next problem
Old Oct 19, 2015 | 07:15 PM
Poncho92's Avatar
Thank you all for the valuable intel
mrbird
Oct 20, 2015 03:43 AM
lewandom
Oct 1, 2015 08:15 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
lanceflame44
Sep 25, 2015 12:28 PM
armybyrd
Sep 21, 2015 10:28 PM
