Stall Ac on
Old Oct 20, 2015 | 07:29 PM
Tonyy_z's Avatar
Stall Ac on
Hey guys have a 92 Camaro 305 tbi and yeah everything runs fine just everytime I turn ac to on position car stalls out at idle . If I give it gas as I turn on ac it'll run fine and won't stall and ideas guys ? Ac runs fine other than that also
Old Oct 20, 2015 | 07:56 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Stall Ac on
do you feel a big loss of power when you turn it on? (i know you will loose some power when you turn it on) but is there a considerable difference of power?
Old Oct 20, 2015 | 10:27 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Stall Ac on
Your IAC might need to be replaced
Old Oct 21, 2015 | 09:33 AM
Tonyy_z's Avatar
Re: Stall Ac on
dont really feel power loss and I just put a different iac in but it's used one works better than my last
Old Oct 22, 2015 | 12:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Stall Ac on
One thing to check is that the A/C active signal to the ECM is OK. It is a dark green wire on ECM pin B8, needs to have +12 volts on it when the compressor clutch is engaged. This tells the ECM to bump the IAC and idle speed.
RBob.
Old Oct 26, 2015 | 09:13 AM
Grant2k's Avatar
Car: 1992 RS
Engine: Iron 5.7 LS
Axle/Gears: 4th gen rear, 3:42s, Torsen
Re: Stall Ac on
RBob.
My car has the same problem when I turn the defroster on. Does the defroster use the A/C? I haven't tested mine but what would be the solution if you don't see 12 volts at this wire?
Old Oct 26, 2015 | 12:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Stall Ac on
According to the '92 FSM, yes, A/C compressor is requested during defrost.
If no +12 volts on that wire start under the hood and track it down. Likely a splice that is open. The splice is located between the low pressure switch on the accumulator and the high pressure cutout switch on the compressor.
The wire color is possibly light blue, not the dark green I posted previously. This is to ECM pin B8. This is what the FSM shows for wire color.
RBob.
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
blackz281le
Jan 11, 2016 07:51 AM
lt1z350
Oct 7, 2015 02:41 PM
Logan Bryant
Sep 23, 2015 06:51 AM
