HELP. Cracked fuel meter body
Old Nov 7, 2015 | 03:21 PM
spoazzy1's Avatar
Car: '89 Firebird
Engine: 305 TBI V8
Axle/Gears: Stock
I was trying to determine where I was losing fuel and pulled my throttle body to clean it and change out gaskets, etc. using the complete overhaul kit and noticed when I put the one fuel line bolt back into the body there is a big crack! Please tell me I can order just the fuel meter body assembly and not need a whole new TBI!!!!! I can't find the parts online and this is my daily driver. I need to get this on the road.
Old Nov 7, 2015 | 06:16 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: HELP. Cracked fuel meter body
Is this what you're looking for?
Attached Thumbnails HELP. Cracked fuel meter body-fmba.jpg   HELP. Cracked fuel meter body-fmbb.jpg
Old Nov 7, 2015 | 06:51 PM
spoazzy1's Avatar
Car: '89 Firebird
Engine: 305 TBI V8
Axle/Gears: Stock
No it's the bottom piece. You can see the crack here. I found a new part on eBay, doesn't seem like it's something I'm gonna find locally. Whoever had put that fitting in last used threadlock on it, which I noticed why when I found the crack. Only prob is now I cleaned it and removed it, I cracked it more.
Old Nov 7, 2015 | 06:56 PM
antares57's Avatar
Oh, okay. Don't have one of those. I cracked mine where the fuel injector nozzle sits. Good luck.
Old Nov 7, 2015 | 07:39 PM
spoazzy1's Avatar
Car: '89 Firebird
Engine: 305 TBI V8
Axle/Gears: Stock
I ordered a new one, just hope I can get it here readily fast 😩
Old Nov 8, 2015 | 03:10 PM
spoazzy1's Avatar
Car: '89 Firebird
Engine: 305 TBI V8
Axle/Gears: Stock
I was actually able to seal it with ethanol resistant epoxy, and covered the whole piece and seam with gas tank sealant epoxy. So far it is working, fingers crossed it holds enough to get the new part here!!!
jahblah
Feb 23, 2017 06:32 AM
92rsvortec350
Feb 22, 2016 09:32 PM
Sooner84
Feb 1, 2016 11:40 PM
Str8Country
Oct 20, 2015 04:42 PM
Poncho92
Oct 19, 2015 07:15 PM
