Fuel Problems.
Old Oct 19, 2015 | 04:07 PM
Str8Country's Avatar
Fuel Problems.
Hey I'm new to this site and I'm not sure if I'm posting this in the right area. I just bought a 89 iroc but it has the 2.8 v6. Not getting power to fuel pump when the key is turned on. However when we run a hot wire to the fuel pump relay it turns on and starts right up as long as the hot wire stays attached. Where could I be losing my power to my fuel pump? Also while it is running it idles and revs fine but after it runs a while and you kill it, it will not start back without a small shot of carb cleaner but when it gets running it runs fine. So I guess I have 2 questions. Why am I not getting fire to my fuel pump and why will it not start alone without prime after its ran a few minutes? Thanks in advance for any help.
Old Oct 20, 2015 | 02:29 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Re: Fuel Problems.
Hi there,
Check the fuse up near the battery, on the wall inside the front fender. there are two fuses, one is for the fuel pump relay, next to a ground wire. This often gets overlooked.
Old Oct 20, 2015 | 04:42 PM
Re: Fuel Problems.
Originally Posted by ktthecarguy
Hi there,
Alright thanks man I will check it out tomorrow. Out of town for work right now
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
tommy z-28
Oct 6, 2015 10:58 PM
tglennon11
Sep 23, 2015 05:30 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
