Throttle body Question
Old Dec 22, 2015 | 07:12 PM
jpnc's Avatar
Car: 1988 GMC C1500
Engine: TBI 305
I have a 1988 GMC Sierra pickup with a 305 engine. I just bought a 1991 GMC Sierra pickup with a 305 engine.
Will the throttle body from the 1991 fit the 1988?
The 91' TBI # is 17091041
C 1891 KDL
The 88' TBI # is 17087019
0778 JNL
I think they are both 220 TBI....not sure
Thanks for any help!
Old Dec 23, 2015 | 08:21 PM
Schurkey's Avatar
Re: Throttle body Question
The TBI will bolt on. The sensors on the side of the TBI may have different connectors.
You may find that the castings are a bit different, but I've swapped a later casting onto my '88 K1500 5.7L.
Original '88 TBI casting and "open" base gasket
Newer-style TBI casting, and fully-divided base gasket.
Gasket part numbers are in the lower-left corner of each photo. Use the proper gasket to match the TBI style.
Old Dec 24, 2015 | 06:30 AM
jpnc's Avatar
Car: 1988 GMC C1500
Engine: TBI 305
Thank you for the information Schurkey!
I'm going to take both of them off today. I appreciate you taking your time to post the photos. I get a better understanding about it now. Thank you!
Old Dec 24, 2015 | 08:36 AM
Schurkey's Avatar
I forgot to mention that if the sensors use different connectors, you can swap the sensor from your original throttle body to the replacement, so you maintain the original wire harness ends. It may be that only the TPS connector is different--I can't remember.
The throttle bodies in the photo above used the same connectors--I don't know when GM switched castings, or when they switched connectors. The replacement throttle body I used came off of a big pile of throttle bodies in a Treasure Yard. I don't know what year it is except it's newer than '88.
Old Dec 25, 2015 | 06:47 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Schurkley
IRC around 1990 is when GM went to a small round TPS plug in passenger cars. Before that there were two different TPS's - straight up and L shaped. Just use the right gasket and swap out TPS plug to match TPS mounted onto TB. BBC used a different IAC plug and IAC motor.
//RF
Old Dec 26, 2015 | 04:40 AM
Schurkey's Avatar
Originally Posted by RFmaster
Schurkley
//RF
Thanks for that. I didn't know BBC was different.
Old Dec 26, 2015 | 10:41 AM
RFmaster's Avatar
Car: 75 Beast
BBC TB
SBC
Also - Majority of BBC TBI do not have provision for TV cable pivot! This makes quick swaps into 700R4 equipped cars difficult.
///RF
WASyL
Jan 17, 2016 02:36 PM
bubbaz28
Dec 21, 2015 08:57 PM
89bird2.8
Dec 20, 2015 11:38 PM
jpnc
Dec 17, 2015 07:30 PM
BrianH33478
Dec 17, 2015 03:05 AM
