305 TBI: correct idle speed?
Old Mar 14, 2016 | 10:52 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I have a 1991 Camaro 305 TBI. It seems like the idle is kind of low to me. When it's in park and warmed up its at about 750 which seems good to me,but when it's in drive and I'm stopped at light or something th idle is 500-525 tops without cooling fan,A/C,radio,or headlights on. The car sputters a little bit while I'm stopped,and if the cooling fan or A/C clutch kicks on the car nearly stalls,and sometimes it has.
Old Mar 15, 2016 | 11:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 305 TBI: correct idle speed?
Sounds correct. In P/N there is no set idle RPM, just an upper and lower limit.
In drive the desired idle RPM is set at 525, with a +-25 RPM dead-band (AXKT).
As for the RPM dip when the A/C kicks in, it could be a sticky IAC. The A/C on has an IAC bump to help prevent this. I don't believe that the cooling fan does as it isn't controlled or monitored by the ECM.
RBob.
Old Mar 15, 2016 | 03:12 PM
Car: 1991 Camaro RS
Engine: 305 TBI
RBob.
Ok well it's nice have some reassurance. Thank you.
IROC ERIC
Apr 1, 2016 03:24 PM
Malisa Halls
Apr 1, 2016 02:47 PM
85@IRocZ
Mar 14, 2016 10:55 PM
edwardk12687
Feb 21, 2016 05:20 PM
67z28
Feb 19, 2016 05:56 AM
