Car randomly dies while driving/idling??
Old Mar 11, 2016 | 11:27 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I've had my 1991 Camaro 305 TBI driving around for roughly a month. At the time I had all major issues fixed,and the engine was running great. Today I took it out to see how the handling improved after getting tires balanced. I was stopped at a 4 way stop,and the car died. I had no idea until I went and tried to turn the wheel and it wouldn't budge. At first it wouldn't even crank over,but I think that's cause I still had it drive (bad idea I know,but people were honking at me like crazy) or cause I had to turn the key off first. I got it to start,and got back on the highway. I suspected it was cause I was using my freshly charged and probably leaking air conditioning,so I shut it all off. I ended up stalling doing 65MPH in front of 18 wheeler,and I was sweating bullets trying to pull over. At that point I knew I couldn't trust the car,and took safest way home. I was about 3-4 miles away from home still,and I ended up stalling 3 more times (5 total on the road) before I got home. It started right back up every time aside from the first time. About a half hour later at home I started it up to swap spots with my brother,and it stalled in 5 seconds of being in park and just idling.
Before all this I rebuilt the throttle body,put in new injectors,new IAC valve,and new MAP sensor. Personally I'm leaning towards a bad fuel pump,but I'll wait to confirm that till I do a bit of trouble shooting for one. What else do you think it could be? How should I go about trouble shooting other stuff?
Old Mar 12, 2016 | 02:38 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Car randomly dies while driving/idling??
Sounds like it could be the fuel pump.
Also, I do not believe the IACV comes preset.
There is a procedure necessary.
It really should be reset during what is called the "Setting Minimum Idle Speed" procedure.
That procedure requires some sort of Digital Tachometer like you would find on a digital timing gun. An aftermarket digital tachometer gage installed would also work.
By the way, if its off, setting "Min. Idle Speed" is a very important thing to do. Its basically the foundation the ECM relies on.
Old Mar 12, 2016 | 03:16 AM
Schurkey's Avatar
What is your fuel pressure?
When my TBI pickup had stalling problems, it was the pickup coil on the distributor mainshaft. It finally died "forever", 250 miles from home. Chevy dealer installed a new main shaft in the distributor. A replacement distributor would be essentially the same.
Old Mar 12, 2016 | 09:52 AM
Car: 1991 Camaro RS
Engine: 305 TBI
I've driven nearly 300 miles on the new IACV and never had an till now. Could that really be a problem?
Old Mar 12, 2016 | 09:53 AM
Car: 1991 Camaro RS
Engine: 305 TBI
I don't know yet. I'll see if I could maybe rent a gauge at autozone or something.
Old Mar 12, 2016 | 10:49 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Just an update. I started it up today and I couldn't get it to stall. I could get it very close though by pressing the gas then releasing it quickly. Something new that it's never done before happened. I had it in park and idling. The RPMS went up and down from 650 to 800. It did this rather quickly too. I didn't have the A/C on,lights,radio,and the cooling fan wasn't on yet. The injectors seemed to be firing fine and giving a good pattern. I sprayed starting fluid in while it was idling and if I got just the right amount in it would rev up 250 RPM. I'm not totally sure what all this means. My guess is that,the computer isn't calculating air/fuel properly due to a freshly bad sensor or vacuum leak,the fuel pump is getting weak,or the filter is plugged.
Old Mar 13, 2016 | 07:35 AM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Go to Harbor Freight and get a fuel pressure tester for $20 bucks. Or rent one from Autozone. This is a must have for troubleshooting fuel delivery problems. It helped find a bad FPR and get my bird running like a champ!
Old Mar 13, 2016 | 11:21 AM
Car: 1991 Camaro RS
Engine: 305 TBI
It looks like I'll be going to harbor freight. Autozone doesn't rent them by me. When I get one where do I hook it to the fuel line?
Old Mar 13, 2016 | 11:29 AM
Car: 1991 Camaro RS
Engine: 305 TBI
The harbor freight tester doesn't work on "GM throttle body systems" according to their site.
Old Mar 13, 2016 | 11:54 AM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
It worked on the V-6 schrader valve when I used it, so not sure.... But I read the 305 TBI doesn't have a valve. You have to tap into the fuel line with an adapter.
http://www.ebay.com/itm/TBI-throttle...569982&vxp=mtr
Old Mar 13, 2016 | 02:28 PM
Car: 1991 Camaro RS
Engine: 305 TBI
For God's sake! Everything on this car is such a pain in the ***. Well I'm a bit strapped for cash,so could I throw a soft fuel line over the opening of the hard line and hook the soft one up to the gauge? Or is the pressure just too much to handle that?
Old Mar 13, 2016 | 02:42 PM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
30 - 47 psi at the rail.
Yep, you have to have deep pockets and lots of patience to own one of these!!
Old Mar 13, 2016 | 03:26 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
No "rail" with TBI. Fuel pressure in the 13psi range, give or take a couple.
Old Mar 13, 2016 | 03:55 PM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Sorry, I was thinking TPI system.
Old Mar 13, 2016 | 04:16 PM
Car: 1991 Camaro RS
Engine: 305 TBI
So if I hooked up the gauge directly to the line I would see roughly 13 PSI on the fuel pump prime? Or am I just definitely going to have to get that adapter to test running pressure?
Old Mar 14, 2016 | 06:55 PM
Schurkey's Avatar
How are you going to test "running" pressure if you have to disconnect the fuel tubing and install hose over it to test pressure?
Might as well get the proper adapter and do it the right way.
Old Mar 14, 2016 | 10:30 PM
Car: 1991 Camaro RS
Engine: 305 TBI
That's why asked if I'd see 13 PSI on the pump prime or not. If I would NOT see 13 PSI on the prime;then I know I'd have to buy the adapter. My issue is the adapter costs $40 that I don't have,and I have to find a way to squeeze it inbetween the throttle body and that hard fuel line. When I rebuilt the TB I noticed how inflexible the line is,and how little room there is to bend it,so it'd be next to impossible to get the adapter in there.
Old Mar 14, 2016 | 10:35 PM
Schurkey's Avatar
Or you get the adapter that screws into the fuel supply tube in place of the fuel filter.
Amazon.com: SG Tool Aid 37650 General Motors Inline Adapter: Automotive Amazon.com: SG Tool Aid 37650 General Motors Inline Adapter: Automotive
Old Mar 14, 2016 | 10:43 PM
Car: 1991 Camaro RS
Engine: 305 TBI
I didn't even know this existed! This should work. I'll be changing my fuel filter again anyway.
Car: 1991 Camaro RS
Engine: 305 TBI
Thanks a bunch man.
Old Mar 15, 2016 | 12:12 AM
DynoDave43's Avatar
Yep, that's the first I've seen of that design too. Not entirely handy having to hook up the gauge under the car, and you're not going to prop it between the hood and windshield to watch the pressure while you drive, but it would be easier to install, that's for sure.
Old Mar 15, 2016 | 03:14 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Yea it should save me from braking my fuel line too.
Old Mar 15, 2016 | 04:00 PM
Schurkey's Avatar
It's a flat-out pain in the azz. OTOH, it's the only way to access fuel pressure in some vehicles. Helps if you have a REALLY long hose on your fuel pressure testing gauge.
Old Mar 16, 2016 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would open the flex line between the chassis and engine to tap into. Even though the above is a nifty tool, I would be hesitate to remove the fuel filter and run the pump.
RBob.
Marucci714
Carburetors
Feb 23, 2016 06:01 AM
anesthes
Feb 21, 2016 08:20 AM
ezbyrd
Feb 17, 2016 06:38 PM
Daslapper88
Feb 16, 2016 09:48 PM
82Brlinetta
Feb 14, 2016 08:53 PM
