[Sold] Stealth Ram, throttle body, injectors.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Speedmaster Stealth Ram intake. Base welded and milled to cover up to a 1206 port. Holley fuel rails and adjustable fuel pressure regulator. -6 feed and return. Throttle body. $450 plus shipping
I also have some 24# Accel fuel injectors I can include for $100
Make offer, trade, etc.
-- Joe
-- Joe
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Stealth Ram, throttle body, injectors.
Why are you selling? Can I get pics of the bottom side I would like to see the milled/port work please
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
1) I wanted to use a large cap HEI dizzy so I didn't have a remote coil
2) I like the 1pc design of the miniram
3) The miniram is shorter, which I just like the looks
4) I think the port design on the miniram (injector protrusion) is superior.
Anyway. Here is some pics. You'll notice I didn't port it all the way to a 1206. It's like a 1205ish right now. The picture of the gasket on it is a 1206 gasket. I simply welded it, and had the machine shop mill it flat so it would cover the ports on my AFR heads.
-- Joe
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
I got a miniram. I had a number of reasons for going to the miniram, some may sound dumb, but it's me:
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Maybe.
I say maybe because, it was just pointed out to me like 2 days ago that the bosses on either end of the intake are intended to allow drilling of the vortec head pattern.
However, I'm unsure if the intake runners line up. I've got some vortec gaskets in the shop, but no way of "centering" them on the intake to be sure.
So I'm not guaranteeing a thing. You can probably chime in on the thread where this intake was discussed.
-- Joe
-- Joe
is there a part # for the intake? what heads were you using before you took it off? thanks
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Bald_eagle_machine
Feb 12, 2016 08:24 AM
cattiveria665
Camaros Wanted
Feb 8, 2016 09:09 PM
