How many IAC counts do you guys have at idle???
Old Dec 24, 2001 | 05:12 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
After I installed the 48mm TBI, my laptop crapped on me so I really didn't get any first hand data. I got WinALDL going again and now I find my IAC counts at idle are around 14! They used to be like 32 and 35.
The vacuum holds fine where it used to at about 33-35 kPa. Could I have a vacuum leak?
I opened the throttle plates a smidge with the adjustment screw and drove around like that for a while (laptop crapped again). Then last night I was on my way home and saw that the IAC counts were 0!!! It idled just fine as always, right at 575 RPM and 33 kPa.
Any thoughts?
Old Dec 24, 2001 | 05:40 PM
Brent's Avatar
10 - 20
Opening the throttle blades requires the IAC to close to maintain the programmed idle speed. That is why you are at 0 now. Close the blades a hair to get the count up a tad.
Old Dec 24, 2001 | 06:02 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
as long as you don't think I have a vacuum leak I'm cool.
I have to keep the throttle screw turned in just enuf to keep the plates from "jamming" in the bore. The plates came out of a TPI 'body, and the bevel on the plates is setup so they are at more of an angle than the TBI plates. So if I close the throttle too much they stick, and that sucks when you're going the drive thru at Taco Bell and the throttle plates snap open.
Old Dec 26, 2001 | 09:09 AM
fast_broker's Avatar
0 - 5 with the bigger cams, 5-15 with the smaller cams.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
