Budget Friendly Bolt On MOD's for the L03
Old Jul 6, 2016 | 01:20 PM
  #51
Schurkey's Avatar
Re: Budget Friendly Bolt On MOD's for the L03
So, a person has a vehicle originally equipped with a 048 module. The module fails.
How does he repair the vehicle WITHOUT installing a used 048 module? NAPA and AC-Delco say to just slam one of their replacement modules in place. The TP25 or the D1943A replace the 048 module. They ALSO replace the 369 module. NAPA and Delco don't mention having to revise the latency tables to suit the replacement module.
You're saying that a module change alters the timing curve. In my case, I just dropped a 369 module into a vehicle that apparently came with an 048. Now my timing curve is different?
I can't say about the 8-pin modules, but the four, five, and seven pin modules control dwell. I would expect the 8-pin module to control dwell in the same fashion--the module monitors current to the ignition coil, then provides a bias voltage to the pickup coil that alters the total voltage in the pickup coil and lead wires. The pickup coil "signal" voltage and the bias voltage work together to provide a recognizable "turn-on" trigger to the module, that begins the dwell period. The trigger can be earlier or later in the reluctor rotation, which alters when the ignition coil current is turned "on". Of course, the negative spike as the reluctor tooth passes the pickup coil tooth is the "turn off" trigger. The "on" time varies with the bias current to keep the total time "on" (the dwell) at a reasonable figure.
I don't know why that function would be removed from the module and installed in the ECM. The ECM would have to send it's bias control signal through the ignition module anyway, since the module is connected to the pickup coil, while the ECM isn't.
You say that aftermarket "ICMs" current limit the coil at a lower current than the GM "ICMs"; that means that the module is controlling the dwell. If it was the ECM, the dwell--and therefore the ignition coil current--would be the same.
Ain't reverse-engineering fun?
Old Jul 6, 2016 | 03:29 PM
  #52
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by RBob
To be honest I wouldn't use it. I would get an AC Delco 369 ICM.
One thing that bothers me about the Dyna module is that they claim it controls the dwell. With stock ICMs the ECM controls the dwell, and does so quite well. I've also seen aftermarket ICMs current limit the coil at a lower current then the GM ICMs.
RBob.
Thanks RBob. I'll scratch that one off the list.
Keep asking questions Schurkey...learning new things all the time here.
I think.
Old Jul 6, 2016 | 03:32 PM
  #53
RBob's Avatar
Car: check
Engine: check
Transmission: check
What do you want me to say? Yes, changing from the 048 ICM to the 369 ICM, the timing curve will change. Others have discovered this when they too swapped ICMs.
With the small cap distributor (8-pin module) the ECM controls the dwell. Except during cranking where it goes to the maximum possible.
The ICM controls the maximum current through the coil. If the dwell is longer then it takes to reach the current limit, the ICM flatlines the current at the limit and holds it until the plug gets fired.
RBob.
Old Jul 6, 2016 | 10:04 PM
  #54
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
2. Welcome to "Problem-Based Learning". You'll learn as you solve problems. This is difficult, but effective. You'll certainly retain what you learn--but--you'll learn a lot of stuff "the hard way".
This is by far the most effected way to learn. Because its purely hands-on approach with direct relevance to your desired outcome.
I would like to say that 90% of what I know about cars comes from research performed due to a problem I was having. The nice thing is that the more you fix, the more you increase your general knowledge.
Old Jul 7, 2016 | 01:21 PM
  #55
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Thank you Thirdgen89GTA,
I had to step back for a second the ICM debate got way outside of my area of expertise. Wasn't bad info, just more than what I was planning on diving into lol.
Old Jul 7, 2016 | 01:26 PM
  #56
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old Jul 7, 2016 | 02:47 PM
  #57
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
All you need to know is the 048 starts killing your power over 3500 RPM and the 369 starts pumping up your power over 3500.
Old Jul 7, 2016 | 02:49 PM
  #58
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
What power is this you speak of..
Old Jul 7, 2016 | 03:33 PM
  #59
All I need to know is that Rbob is one of the Giants here on TGO and what he writes, I read and pretty much take as fact.
Old Jul 7, 2016 | 03:58 PM
  #60
Schurkey's Avatar
And yet, if you don't use the 369 module with the correct latency table, apparently you won't get appropriate results.
Don't think that I understand this any more than you guys.
Old Jul 7, 2016 | 04:06 PM
  #61
chazman's Avatar
Axle/Gears: BW 3.45
A relative term.....
Old Jul 7, 2016 | 07:48 PM
  #62
DynoDave43's Avatar
Old Jul 7, 2016 | 10:25 PM
  #63
A long time ago, in a galaxy far, far away. A L03 started accelerating to 60mph, today that goal has been achieved.
Just giving the TBI some crap, cause its tradition by now.
Old Jul 8, 2016 | 08:01 AM
  #64
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
You guys are funny! DynoDave you got a good laugh out of me! A soccer mom in a Nissan Murano made me decide not to go any farther with my L03. I will just build another engine for later down the road and enjoy my great gas mileage and reliable lil swirlport engine for now
Old Jul 8, 2016 | 03:24 PM
  #65
DynoDave43's Avatar
Dating myself here...I heard Del Reeve's at a concert describe a member of his band as being like a little camp fire off in the woods. Warm, friendly, but not too damn bright.
I think of the L03 sort of the same way. It's a good little engine, reliable, moves along OK, but not very fast.
Modern vehicle give us fits for sure. I always take the high road, and refuse to street race. That's my story, and I'm sticking to it.
My current L03 is my 3rd one, so obviously I have no qualms about owning one.
But you've got 3.73s behind yours, dmccain. What are you complaining about!
Old Jul 8, 2016 | 03:41 PM
  #66
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Custom chip, bumped up fuel pressure,S10 torque converter, built 700R4, 3 in exhaust cat-delete.. still slower than the Murano! Lol. Im ok with it for now Dave but when my 350 or 400 sbc which ever I decide to build goes in...I will make sure I can at least run with factory pickups and most grocery getters today which is a tall order when pretty much stock pickups run close to 13sec timeslips these days.
Old Jul 8, 2016 | 04:23 PM
  #67
Engine: 305 / 350
Love the L03 Meme DynoDave43! LMAO @ Thirdgen89GTA I nearly died
Old Jul 14, 2016 | 01:17 AM
  #68
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Newer cars will give you hell for sure! My Japanese 4,000 lbs luxury 4 door sedan has run a 12.94 @ 108 mph BONE STOCK on 245 street tires. Put down 382 hp and 390 tq on a Dynojet stock. With a custom 2.5" dual exhaust, custom tune by me, and a 170°F thermostat it put down 428 rwhp and 430 rwtq with ZERO internal engine mods.
Old Jul 18, 2023 | 11:03 PM
  #69
chazman's Avatar
Axle/Gears: BW 3.45
Not to bring up an old thread, but do we have a current part number for the 369 ICM?
Old Jul 19, 2023 | 07:51 AM
  #70
aliceempire's Avatar
Transmission: T-5, TH350, T-5
According to this, https://www.thirdgen.org/forums/dfi-...-ignition.html
The new number is this,
https://www.summitracing.com/parts/ado-d1943a
I'm not backing that up with firsthand knowledge, just what my search lead to
Old Jul 19, 2023 | 11:42 AM
  #71
chazman's Avatar
Axle/Gears: BW 3.45
Who can identify this ICM? I was expecting to see either 048 or 369 when I lifted the cap. It’s from an ‘87 LG4
Old Jul 19, 2023 | 02:44 PM
  #72
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.napaonline.com/en/p/ECHTP25
Old Jul 19, 2023 | 04:27 PM
  #73
chazman's Avatar
Axle/Gears: BW 3.45
Excellent! Thanks!
Probably 369?
Old Jul 20, 2023 | 08:22 PM
  #74
JeepYJv8's Avatar
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
I lean on the more negative side. Just keep it up to date on maintenance or put some nitrous on it. I feel you either need to change everything or nothing. Best bang will always be a little nitrous to have a little fun.
these performance mods are out of hand. I saw a .25 injector pod spacer claiming some large HP increase. It's all a sales gimmic. Throttle body, cam. Heads. Exhaust. And all of them or nitrous. Only real options.
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
BG1959
Jul 20, 2016 02:22 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
tcrisp
Apr 5, 2016 01:03 AM
