anyone need 1.6 AND 1.5 rockers
Old Dec 28, 2001 | 01:03 PM
fast_broker's Avatar
I cannot get a vendor to split-up the Proform Chromoly stamped, roller-tipped self-aligning sets of 16 rockers. I need 8 of 1.5 and 8 of 1.6 ratio.
My question is, does someone else here need the same??? ie, 8 of Proform P/N 66926c and 8 of P/N 66927C SELF-ALIGNING roller-tipped rocker arms, 1.5 and 1.6 ratio, respectively?
Like $130 for a set of 16. Eddie needie... in my case this combo will help a ZZ4 cam go from .475"/.510" lift to 505"/.510" lift, that is why I need them. They also reduce friction at the valve stem tip and reduce valve guide wear CONSIDERABLY as the lateral loading on the valve stem is reduced as a result of the reduced valve stem tip friction.
You only need them if your lift on the intake is too small OR if you have a single pattern camshaft (same intake/exhaust lift and/or duration) and youwant to help the usually-feeble exhaust ports out a little by running 1.5's on the intake and the 1.6s on the exhaust side.
Doesn't hurt to ask...
Old Dec 28, 2001 | 02:13 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Man, if my cam were a little smaller, I might take you up, but I'm thinking of getting some Vortec heads...
Old Dec 28, 2001 | 08:07 PM
your cam doesn't need 1.5/1.6 treatment. Good cam. I remember...
pls don't reply unless you want to split 1/5/1.6 rockers. i will front the scratch.
Old Dec 28, 2001 | 09:21 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Fastbroker,
I have been thinking of doing a split on rockers. I currently have a set of Crower Stainless Steel full Roller and would like to upgrade the intakes to 1.6
Currently, my cam profile is a 212/218 488/495 with 112d LSA. The TFS 23d heads have a stall speed of .500" so I would like to maximize the intake side. If you are interested let me know. Th 1.5's I have have about 3000miles on them. BTW, they fit under the stock Xfire valvecover.
Old Dec 30, 2001 | 05:39 PM
Are they SELF-ALIGNING??? I need self aligning...
If so, I am very interested. Call me at work Monday, tomorrow, i f you can between 9:30 and 11:00 Eastern, toll-free at 1-800-833-3405, Ed Hovan. I'd liek to maybe get the 1.6 Crowers to match???
Old Jan 1, 2002 | 01:30 PM
Going once...
I'll front the money and pay the shipping to you house!!! (big spender)
Old Jan 2, 2002 | 09:55 AM
Going twice...
Old Jan 2, 2002 | 12:34 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Fastbroker,
Did you see these?
http://cgi.ebay.com/ebaymotors/aw-cg...item=599697926
Old Jan 2, 2002 | 12:42 PM
Thanks, Dom!
Will they fit under centerbolts??? I assume so
Old Jan 2, 2002 | 02:17 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Ed,
Let me know how you make out. One of the reasons I chose the Crower Stainless Steel rockers was because they would fit under the stock valve covers. Mine are perimeter bolt but with a slight pinch of the PCV valve area, the fit fine without hitting the oil drip casting.
Old Jan 2, 2002 | 02:23 PM
Those Ebay Crowers ended in a seller ending the auction prematurely. Crank head.
When we spoke the other day, I neglected to tell you that when youa re checking your valve-to-piston clearance, you should install very weak "installed-height" valve springs wihch make the job easy to do with your fingers, aftre you go through the trouble of changing valve springs with the heads on,, that is.
Old Jan 2, 2002 | 03:32 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Ed,
Thanks. I think I'll have plenty of room for clearance. And I'll be doing the intake side so that's less critical.
Old Jan 2, 2002 | 04:01 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Ed,
Just checked with Summit. Crower sells half-sets of rockers so you can mix and match. I just picked up a set of 8 of the 1.6 Stainless Steel Full Rollers. $212
Old Jan 2, 2002 | 09:15 PM
http://cgi.ebay.com/ebaymotors/aw-cg...item=599789971
I couldn't wait for help. I bought these and called them and bought some 1.5's as well. thanks.
Old Jan 2, 2002 | 09:26 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Ed,
I would have bought the CompCams ProMagnum if I hadn't already had a set of the Crower 1.5's. I bought them largely because I wanted to make sure they fit under the stock valve covers and that's what Gary Grimes recommended. I didn't want aluminum because of the fact they thrash themselves to death eventually. Good luck with the Comps. Looks like I'll have half a set of roller rockers to sell. I've also got a full set of CompCams
Magnum roller Tip 1.6 rockers that are in excellent shape.
Old Jan 3, 2002 | 07:49 AM
I'm not big on Aluminum, either. Not long lasting.
These Comps are a new SA design, rebuildable and stainless. go to page 267 (??) of their online catalog and they actually have a picture of them at the botom of the page. That picture in the Comp catalog sold me. They were $320 everywhere else I checked. Hope they don't rip me off!!!!!!!!!!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
