failed emissions , HELP!!
Old Dec 29, 2001 | 11:50 PM
vjo90RS8's Avatar
Car: 2002 Z28
I failed CA smog today, here are the readings
2500 RPM
HC: 140 max, 39 measured
CO%: 1.00 max, .42 measured
IDLE RPM
HC: 120 max, 225 measured
CO%: 1.00 max, 2.12 measured
He said my car is probably running rich at idle, he said a new O2 sensor might help, so i went out and got a new Bosch sensor. Do you think that will help. I also have a new cap, rotor and coil (MSD) that i have been meaning to put on, it this a good time to install them? will it help. I was also thinking about finally making my pressure regulator functional and just lowering the fuel pressure. What should i do??/
THANKS
Old Dec 30, 2001 | 12:27 AM
TBI305Camaro's Avatar
id say if you go in running as lean as possible you would pass unless you failed miserably...here in WV we dont have to get sniffed...not yet anyways and if we do i mid as well burn my car...
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
