Capping cruise control vacuum port on intake cause any problems?
Old Apr 3, 2017 | 07:17 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all im trying to find a vacuum leak and i was just curious if i could just pull off the vacuum line from the port at the intake back between throttle body and distributor and cap it? the cruise control in the car has never worked anyways so its not used.
Just curious if capping that port on the intake would cause any problems.
thanks all
Old Apr 5, 2017 | 01:18 AM
Schurkey's Avatar
Re: Capping cruise control vacuum port on intake cause any problems?
Does that port supply vacuum to anything other than the cruise control?
If not...no problem.
Old Apr 5, 2017 | 01:37 PM
I believe the hvac gets vacuum for somereason of it as well but the heater core isnt even hooked up, dont use heat/ac.
I just capped it that night and havent had any problems. Didnt fix my vacuum leak unfortunately.
Old Apr 5, 2017 | 04:04 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
get any air flow through your floor or AC vents or is it only through the dash defrost vents?
Old Apr 6, 2017 | 01:41 PM
airflow? none, not even through the dash defrost vents? what do you mean lol
