89 Chevy camaro tbi
Old Jun 20, 2017 | 04:27 AM
Taskmaster1227's Avatar
89 Chevy camaro tbi
I have a 89 Chevy camaro 305 tbi I recently changed my injectors ran the car for about 15 mints then noticed a lot of fluid leaking from behind the harmonic balancer with a closer look I figured out it was gas. any solutions ? oh and now I smell gas mixed in with the oil and car won't turn over.
Did I damage anything?
How do I fix this? any help would be greatly appreciated car is my daily need it back running I know the injectors are no good so I will have to change them and the gas mixed oil but wht about the gas in the oil did I mess any seals or gaskets up internationaly plz help
Old Jun 20, 2017 | 09:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 89 Chevy camaro tbi
Most likely you didn't get the injector o-rings installed correctly. Which would end up flooding the engine with fuel. May even have a cylinder or two hydro-locked with fuel (pull spark plugs out to drain).
RBob.
Old Jun 20, 2017 | 09:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
See this post:
https://www.thirdgen.org/forums/tbi/...ml#post3875416
RBob.
Old Jun 20, 2017 | 03:40 PM
Thanks RBob.
