what is this plug?
Old Jul 30, 2017 | 07:51 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
what is this plug?
took my air cleaner off today and found this unplugged. what is it?
Attached Thumbnails what is this plug?-thumbnail_20170730_175509_resized.jpg
Old Jul 30, 2017 | 09:36 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: what is this plug?
IAC on the left, throttle position sensor on the right.
Old Jul 30, 2017 | 10:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Maybe I'm blind, but I don't see anything unplugged. Where are you referring
to?
Old Aug 1, 2017 | 08:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You need a new IAC connector, the square 4-wire on the left. The terminal retention flap is gone and there are terminals pulled out of the connector.
RBob.
Old Aug 1, 2017 | 01:32 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Ah yes, upon closer examination it looks just like the one on my car I've been meaning to replace. Thanks for the slap on the head I needed
Old Aug 1, 2017 | 06:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://m.ebay.com/itm/IAC-Valve-Conn...%257Ciid%253A1
You can just replace the male terminals at mouser.com
Old Aug 3, 2017 | 09:51 PM
Evilokc's Avatar
Engine: tbi 305
it was the i.a.c. It was plugged back in when I took the pic. the plug is broken. I'm gong to replace it.
Old Oct 9, 2018 | 07:19 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Wrong thread.
Old Dec 14, 2018 | 09:19 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Old Dec 22, 2018 | 11:38 AM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
was on freeway yesterday am hit some in the
road couldn't avoid too much traffic. car quit running so weed it home went out to check dame today and found this. also took out cranks sensor i believe thats why quit running
Old Dec 22, 2018 | 05:58 PM
Engine: Lb9
Transmission: M20
What does this have to do with the op iac ??
Old Jan 12, 2019 | 09:29 PM
Evilokc's Avatar
Engine: tbi 305
Old Feb 2, 2019 | 01:33 AM
gpwasr10's Avatar
Car: 1989 Iroc-Z Hardtop
Axle/Gears: 9 Bolt 2.73 Posi
Put the finishing touches on a full Header Back Exhaust. Sounds Bitchin'.
Old Feb 2, 2019 | 12:43 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Not only that, but this as well. Is this just random post anything in a IAC specific thread week?
Old Feb 2, 2019 | 02:15 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
accidentally posted in wrong thread
Old Jun 12, 2019 | 10:21 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I removed the old spoiler and pulled the rear bumper. I also sanded down my 3rd brake light bracket removing all the paint. My restore journey begins!
Old Jun 12, 2019 | 10:29 PM
Engine: Lb9
Transmission: M20
What ?
Old Jun 13, 2019 | 01:09 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
In this thread we find out who still has "endless scroll" on in their forum options.
Old Jul 5, 2019 | 08:12 AM
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
I didn't do it personally but had the cracked flexplate replaced along with a leaking differential gasket and a rusted brake line. No more rattling from the flexplate thank God. Also, had the starter replaced because it was on the way out.
Carlos
Old Jul 5, 2019 | 02:59 PM
Sweatlock's Avatar
I pulled it out and I think I broke it, or at least it’s now at a funny angle. Can this be repaired/ straightened?
Thanks!
Old Jul 5, 2019 | 04:11 PM
Schurkey's Avatar
Thanks!
Ask her if she LIKES the funny angle. Some women don't want it straight. You might come out ahead on the deal.
Any chance this thread can be locked?
Old Jul 6, 2019 | 02:25 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Or just delete the posts (including mine) that have nothing to do with the original question.
