Holley Projection Connectors
Old Sep 4, 2017 | 07:52 PM
ur7x's Avatar
Car: 83 Z28, 87 442 (Sold)
Engine: 5.0, 5.7,
Transmission: 4 Speed autos
I got a used Holley Pro-jection (2bbl) system that I'm considering swapping into my 350 9C1 TBI.
However the injector connector pigtail is missing.
Does anyone know what the part number that 4 pin connector is?
Old Sep 4, 2017 | 08:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Holley Projection Connectors
Just curious but doesn't the projection use a high impedance injectors?
Old Sep 7, 2017 | 12:37 AM
Schurkey's Avatar
If it's anything like the 2bbl replacement TBIs that Holley sold as "interchangeable, emissions-compliant" substitutes for the original TBIs, there is an "old" injector style and a "new" injector style.
If the injectors have a rounded, rubber cap over the top, they're the old style.
If the injectors have a molded plastic connector for a plug-in harness, they're the newer style. Holley has replacement harnesses. Not cheap!
If you have the newer-style injectors, look at a Holley harness p/n 534-167.
https://www.summitracing.com/parts/hly-534-167.
I had to order one of these for my 502-6 replacement TBI unit. I also ordered a pigtail to plug into the 4-wire molded plastic connector which would then splice into the OEM harness.
Amazon Amazon
Old Sep 7, 2017 | 01:50 PM
ur7x's Avatar
Engine: 5.0, 5.7,
Thanks so much it is a newer style.
So you are saying that a pigtail like this
http://www.ebay.com/itm/GM-Ignition-...RTiuhS&vxp=mtr
would work?
If I use this, I was going to drive it with megasquirt or an EBL ECU.
Old Sep 7, 2017 | 02:49 PM
Schurkey's Avatar
would work?
Looks right, based on what I remember.
