Defective IAC ?
Old Oct 4, 2017 | 08:18 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Defective IAC ?
I replaced the IAC a couple of weeks ago, but I figured out that my EGR was causing problems. I ended up reinstalling my old IAC, because the one from Advanced Auto didn't work. They let me exchange it, but wouldn't refund my money, so I tried the second one, and it didn't work well either. Could they have sold me two bad ones in a row or am I missing something?
Old Oct 5, 2017 | 03:29 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Defective IAC ?
Did you first make sure the pintle was pushed in far enough and set minimum
air as described in the How-Tos section?
Old Oct 5, 2017 | 03:34 PM
Re: Defective IAC ?
No, I just put it in like I've done before.
Old Oct 5, 2017 | 03:42 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Defective IAC ?
If the punter is out to far it will damage the iac iirc 1 1/8 extended is about as far out as it should be to avoid damage.
Old Oct 5, 2017 | 03:51 PM
Engine: Lb9
Transmission: M20
Re: Defective IAC ?
https://www.thirdgen.org/tpimod2/
Old Oct 6, 2017 | 12:00 PM
Re: Defective IAC ?
Geez, I should have checked this out. No my parts guy is walking funny, and it's all my fault. :-)
Old Oct 6, 2017 | 01:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Defective IAC ?
Where is this posted at Tuned? I would have "assumed" it would be a sticky at the top of this TBI sub-forum, but I don't see it there.
Old Oct 6, 2017 | 01:40 PM
Engine: Lb9
Transmission: M20
Re: Defective IAC ?
Red banner at the top of your page how-tos. It’s for tpi but still applies to tbi .
Old Oct 6, 2017 | 02:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Defective IAC ?
It actually is for TBI. No idea why it has that URL??
Old Oct 6, 2017 | 03:08 PM
Engine: Lb9
Transmission: M20
Re: Defective IAC ?
Does the thirdgen tbi have a adjustable tps ?
Old Oct 6, 2017 | 04:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Defective IAC ?
Early ones do
Old Oct 6, 2017 | 04:27 PM
Re: Defective IAC ?
I've replaced about every sensor known to man on my third gens, and they are all plug n play, at least as far as I know. I didn't look at the how tos, cause it just didn't occur to me. I mean who reads the directions? I do think it should be a sticky in both tbi, and tpi if you ask me.
Old Oct 6, 2017 | 05:15 PM
DynoDave43's Avatar
Re: Defective IAC ?
See it everyday, and don't notice it. Thanks Tuned.
Old Oct 10, 2017 | 12:23 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Defective IAC ?
After the IACV is installed you jump the A to B terminals under the dash and turn the key on. Do not start it.
You will be able to hear the pintle in the IACV clicking.
Let it do that for 45 seconds.
That is the valve resetting its self.
Turn the key off and remove the jumper.
This actually should be done like this though.
In this procedure the IACV is properly reset.
"Setting Minimum Idle Speed".
1)Jump the A to B terminal under the dash in the ALDL Terminal as seen below.
2)Turn the key on but do not start it
3)You should hear a slight ticking coming from the IACV.
4)What 45 seconds then unplug the IACV with the ignition still on.
5)Disconnect the EST wire and remove the jumper.
6)Start the car.
It may be necessary to hold the throttle open slightly to prevent the engine from stalling.
Allow the engine to reach normal operating temperature.
7)Connect a tachometer. I used a digital timing gun with RPM feature.
8) Adjust the minimum idle speed using the throttle stop screw.
9) My Chilton’s says set it to 700rpm in park on an 89 TBI 5.0 auto.
10) When done shut the car off and reconnect the EST wire.
11) Plug the IACV back in.
Take it easy on the car for the first day or so.
Drive it normally on the street and highway to allow the ECM to re learn the new parameters.
The car will feel better and better as you do this.
