355 9c1
Re: 355 9c1
If this were me, I'd find a proper torque wrench, fire the engine and run it for ten--fifteen minutes. Shut off the engine, let it cool, and re-torque the heads. I don't see any point to tearing it apart when the bolts are likely "close" as-is.
If "peace-of-mind" is important, well, do what you gotta do. For the record, SBC headbolts are reusable. There's no need to buy another set. Other, newer engine families use torque-to-yield head bolts but the SBC is old enough to use decent hardware.
What sealer did you use on the bolt threads? That may be the important difference--if the sealer is entirely set-up, retorquing may just disturb the sealer and create seepage.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 355 9c1
Car: 1993 Caprice
Transmission: 4L60
Re: 355 9c1
I actually lucked out and used the 3/8 drive. the bolts had stretched. i rechecked with digital torque adapter was within 1.5-2 ftlbs of each other. did the other head as well. put rockers and pushrods in
Car: 1993 Caprice
Transmission: 4L60
Re: 355 9c1
motor is in and have it running decent but since it's gotten warmer the temps rise in idle. drilled 2 holes in 180*stat- no bad spike at warmup. swapped in another fan clutch- temps still reach 194 in traffic and drive thru. just ordered a 4 row aluminum radiator-https://www.alloyworksplus.com/produ...57l-v8-91-1993 hopefully this will help since the 305 had a 1 row. was running 89 octane during fall, winter and spring. now running 93 to avoid ping-may be temp related
Re: 355 9c1
I am fairly certain the newer 1/2" head Vortec bolts are TTY and use TTY torque method. I actually broke one trying to reuse them about 10 years ago. Since then I have always used new bolts on Vortecs. I always replace them with aftermarket non-torque to yeild bolts and use the standard torque method to the spec of the bolts. Usually 75 ft/lbs. My last 3 engines have had Jegs brand bolts. Work great for me. I have reused two sets multiple times. FWIW I never retorque them either. Would be too much of a pain in the *** in a Van especially my Express van.
Be aware that TTY is a variation of Torque-Angle fastener tightening. Torque-Angle tightening does not require yielding the bolt. TTY is just Torque-Angle that spins the head enough to permanently deform the fastener.
Torque-Angle tends to be more precise than just torquing to a higher torque value.
jeremy iroc z28
Oct 25, 2016 03:03 AM
