TBI Injector Identification
Old Apr 5, 2019 | 07:02 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Pic # 1 - My unmodified drivable 92 RS 305 TBI
Pic # 2 - Unknown - On my new project 92 RS which is supposed to be a TBI 305
The injectors in the 2nd pic appear to have red stems w/ RIN-1000 / 1096 & 1210 on top while the injectors in Pic # 1 seem to be orange and I couldn't see any writing on them...
Any insight?
Old Apr 5, 2019 | 07:41 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TBI Injector Identification
Those Orange ones are 55lb. Common 305 injectors.
Old Apr 5, 2019 | 08:17 PM
Engine: 305 / 350
Yea I kind of figured that, the red ones are what concern me. I can't identify them, and it'a making me wonder if it's the original L03 or if someone has done some kind of swap of the motor, TBI or Injectors on car #2. The Injector Pod I pulled off a 91 S10 had injectors w/ the orange stems too, never seen red...
Old Apr 5, 2019 | 10:34 PM
Engine: 305 / 350
One thing I know for sure... the red one's don't appear OEM. From what i'm reading in my service manual (I known I should have looked there first) all OEM TBI injectors are stamped with two stamps. Top line should read GM w/ part number and vendor ID number, the second line should read a 4 digit build date code followed by the GM logo.
Old Apr 9, 2019 | 04:59 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Its not the color of the electrical connectors that matter. Every GM TBI injector that style has orange stems. Its the painted colors in the middle. This was a NOS 300 HP Marine TBI unit. Pink/Purple code high pressure 46 lb/hr injectors.
Old Apr 9, 2019 | 07:10 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
FAST355 I'm glad you chimed in and let me know what to look for. Do you know which color are the 68lbers?
Old Apr 9, 2019 | 01:58 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Yes, is there a table of these somewhere? I'm not seeing one pinned at the top of the page.
Old Apr 9, 2019 | 03:18 PM
Engine: 305 / 350
https://www.thirdgen.org/forums/diy-...ctor-info.html
Original Poster: @Grumpy
Color code Application Flow rate Part #
Black/White 1-3/8" bore 2bbl, from 2.8l truck ??? GM 5235430 *RPD
Yellow/Blue 4.3L ??? GM 5235203 *RPD
Green/White 5.0L 40 lb/hr GM 5235279 *RPD
Orange/Black 5.7L pickup 55 lb/hr GM 5235206 *RPD
Yellow/Brown 5.7L Cop Car 65 lb/hr ???
Blue/Black Late big block pickup 80 lb/hr GM 1708430 *RPD
Dark Red/Dark Blue big block pickup 90 lb/hr GM 5235231 *RPD
Old Apr 9, 2019 | 09:06 PM
DynoDave43's Avatar
Thank you sir. You just knew that had to have been covered before.
Wish we could get a copy of that pinned here under TBI.
Romilin
Jun 21, 2009 02:32 PM
Slow89Iroc-Z
Feb 4, 2002 02:45 PM
jimjohn
Nov 20, 2001 09:00 PM
cobrakiller1989
Sep 10, 2001 11:08 PM
matty350TPI
Apr 26, 2001 11:04 AM
