Anyone else see this?!
Old Jan 10, 2002 | 12:03 PM
FRMULA's Avatar
http://www.haltech.com/Products/ECUs/E6GM/e6gm.html
If this plugs into third gens it would make alot of tuning issues easier. Also from what I read this would allow you to run up to 8 low impedance or 4 high impedance injectors. ie 4 barrell holley tbi's or dual 2 barrel tbi's. something to think about. Don't know how much this ecu costs but the specs on it are pretty cool.
Old Jan 10, 2002 | 01:31 PM
fast_broker's Avatar
I think its 4 low and 8 high...
Old Jan 10, 2002 | 02:03 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Isn't that ECM like $1000 or something?
Old Jan 10, 2002 | 08:55 PM
NJ SPEEDER's Avatar
i just sent them email. good find amn! looks intereesting. when i get the response i will post it up so everyone has the info.
i asked about controlling TBI, what extra parts are needed for it to be a drop in, and price.
later
tim
Old Jan 11, 2002 | 07:11 PM
HrdRockA4305's Avatar
I've asked about that in the PROM board before, about 2 months ago. There is a guy on here with a blown TBI suburban who has one, don't know if he still posts or not. He said he can't imagine tuning EFI without it. I thought it was just too cool. They go for around $550-600 I think, plus you need a laptop. Not cheap but sure beats hit and miss PROM burning. Adjust ANYTHING while the car is running! I had this crazy Idea too.... since they make ECMs to control however many injectors you want (the plug in one wouldn't probably work for this though) that would sure be a good way to run a multi-TBI setup wouldn't it? Or use a Holley 4-bbl TBI. All kinds of possibilities. Too bad I can barely afford to insure and maintain mine, let alone modify on occasion.
Old Jan 11, 2002 | 07:38 PM
Holley makes an extra driver/controller as well. Can't be 1000 bucks or noone would buy it...
Old Jan 11, 2002 | 10:43 PM
NJ SPEEDER's Avatar
i got an email back from them already. i can't believe it, a company that responds to email in less than a week!
here is the story:
1. it is supposed to drop in place of any gm computer with two connectors, one will be a 24pin and the other 32pin(jprevost, is this ours? i think it is, but i was never exactly one for computer tuning.)
2. you have to check to see if the pin out matches up and may have to move some wires around to get it to work right
3. it comes with software, a connector for your lap top, an instruction manual. no adaptors needed
4. it cost about $670 including shipping
i think it sounds like a good deal. i am gonna try to get hte pin outs for our ecm and their drop in unit. if they match up or it looks easy to switch i am thinking it is a good idea. tiem to go shopping fo ra laptop i guess
later
tim
Old Jan 12, 2002 | 12:11 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
do you guys think that there any way to adapt this to work with a 2-barrel system? that sounds fun
-brian
Old Jan 12, 2002 | 12:46 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
One of the guys on the Astro/Safari forum has a Haltech. Here's what he sent me.
: Wiring Diagram of Haltech E6GM:
: PUMP RELAY........A1/B1
: ...........................A2/B2
: ...........................A3/B3 CRANK GND
: ...........................A4/B4
: ...........................A5/B5 CRANK INP
: +13,8V................A6/B6
: TCC CONTROL.....A7/B7
: ...........................A8/B8 A/C REQ
: ...........................A9/B9
: VSS.....................A10/B10
: MAP+MAT GND....A11/B11
: GND................... A12/B12
: THFAN CONTROL..C1/D1 GND
: A/C CONTROL.......C2/D2 T+C GND
: IDL2.....................C3/D3 GND
: IDL1.....................C4/D4 EST OUT
: IDL3.....................C5/D5 BYPASS
: IDL4.....................C6/D6 O2 SENS GND
: 4TH GEAR.............C7/D7 O2 SENSOR
:..............................C8/D8
:..............................C9/D9
: COOLANT..............C10/D10 GND
: MAP......................C11/D11
: AIR TEMP..............C12/D12
: THROTTLE POS.....C13/D13
: +5V......................C14/D14
:.............................C15/D15 INJ1
:.............................C16/D16 INJ2
: PLUG2***
: RX.......................A1/B1 GND
: TX.......................A2/B2
: IGN TRIM............A3/B3 GND
: +5V....................A4/B4
: +5V....................A5/B5 GND
: FUEL TRIM..........A6/B6
I think plug2 might be where you hook the laptop into.
Old Jan 14, 2002 | 07:35 AM
FRMULA's Avatar
This info just in from Haltech:
The E6gm will work on 1986 to 1988 GM cars and some up to
1991. To be sure you should check your ECU to see if it has
2 plugs. One plug with 24 pins and one with 32 pins. Some
post 1988 cars have the 3 plug ECU. The E6gm includes no
harness, only the programming pigtail in included. If you
have the 2 plug style ECU, The plug on the E6gm in the same.
You will need to check the pin compatibility and move pins to
suite. The retail price is $698.00 not including a MAP sensor.
You will need a 1 bar MAP sensor for naturally asperated engines.
The 1 bar MAP sensor is $64.00, Your car may have one or it
will have a MAF sensor.
Haltech USA
PH 972-831-9800
Fax 972-831-9802
www.haltech.com
Old Jan 14, 2002 | 09:22 AM
scauffiel's Avatar
I've got one of these I just haven't played with it yet.
Steve
Old Jan 14, 2002 | 11:23 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
hey scauffiel, in virginia beach i see, so am I.. until the 23rd anyways. Gimme a call if you wanna BS about cars, tbi
it'd be cool to check out another tbi'rs ride that actually is into modding the thing
417-1369
