Need more fuel
Old Oct 9, 2019 | 05:15 PM
tbakertrucks's Avatar
Need more fuel
Ok im running a vortec 5.7 with tbi using a 4 barrel intake and adapter plate. Im using a moates apu1 and trying to adjust the fuel map to give it more fuel however the cells in the fuel table wont go above 99 and stay there. How do we get these values to remain at 100 or more? Also if tables wont go above 100 has anyone else run dual tbi or made a copy of the frankenstein 4 barrel tbi i have seen online.
Old Oct 10, 2019 | 07:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need more fuel
100% VE is as high as they go. Increase the BPC value by 15% and lower the VE table(s) by the same 15%. Continue tuning, keep an eye on the injector duty cycle.
RBob.
Old Oct 10, 2019 | 07:32 PM
Re: Need more fuel
What is bpc? Sorry im a complete newbie to the tuning stuff.
Old Oct 10, 2019 | 09:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need more fuel
Base Pulse Constant
Old Oct 11, 2019 | 08:01 PM
Re: Need more fuel
Ok i think i found my bpc constant, im having issues with my apu1 with datalogging and emulation its like my ecm is stuck in limp mode. Ecm is 16197427 code bnkm im using 94-95 truck bnkm bin $31 xdf and adx fike a219$31v250.adx. If i throw in another ecm 16197427 from a truck that had bjyl 5.7 4l60e trans it will log data under $od so i know its not pc issues but wuen i put my stock ecm in its not letting me emulate or data log when using the correct set up in software. Any ideas
Old Oct 29, 2019 | 06:08 PM
Re: Need more fuel
I do not see base pulse constant in the parameters
Old Oct 29, 2019 | 11:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Need more fuel
7427 PCM...Reduce the injector size parameter.
Old Oct 30, 2019 | 03:58 AM
Re: Need more fuel
Thank you ill try that tonight.
Old Oct 30, 2019 | 09:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need more fuel
What Fast said, $31 doesn't use a BPC value/table.
RBob.
faisal
Carburetors
Nov 13, 2017 09:06 AM
oramac91
Jul 18, 2011 06:29 AM
Birdstheword
Carburetors
Jun 5, 2009 12:02 PM
91 camaro racer
Apr 14, 2007 12:45 PM
1985-Z28
Jan 16, 2001 12:10 PM
