Something everyone should know about Lt1 cam
Old Jan 12, 2002 | 03:14 PM
JPrevost's Avatar
Car: 91 Red Sled
If the word "used cam" scares you understand that the Lt1 is a steel piece. They don't exactly wear out like a normal flat tap. They also let you reuse your stock roller lifters because they too can be reused. I just thought I'd point this out to those of you that might have heard from 'other sources' that a used cam is a thing to avoid.
So if you were every thinking about a cam swap definatly keep the roller setup. The advantages of a roller cam are great in comparison to the price. It's probably the only internal moving piece I would ever reuse from a used motor with unknown milage.
Old Jan 12, 2002 | 04:46 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
So true..........I purchased a used LT-4 cam for my last 305 and it was wonderfull.............Jon is right.
Brian
Old Jan 13, 2002 | 04:20 AM
ZRATED's Avatar
Yup true dat!!! I bought my lt1 cam with unknown mileage and ever since i put in i have had not a single problem with it.
Old Jan 13, 2002 | 11:18 AM
ONEFINE8T9's Avatar
u guys running LT1 CAMS what are u running compared to stock camshaft?
Old Jan 13, 2002 | 01:03 PM
Tallboy's Avatar
spreading info is a good thing but it does make it harder
to find parts when more people know about them...........
i bet even a year ago finding an lt1 cam wasnt as much a task as now
Old Jan 13, 2002 | 04:21 PM
Faithbird88's Avatar
I kinda think now its getting a bit harder to find LT1 cam, personally i just happen to stumbel across mine from a fellow buddy on Thirdgen.org, and it happen to be on e-bay, only payed $20,and it perfect!!!!!
Old Jan 16, 2002 | 12:11 AM
BahamutRS's Avatar
Very true. The LT1 cam I purchased but never used was from a 1996 Vette and it was like brank spankin' new anyways. =D
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
