Code 42 and 44
Old Dec 24, 2019 | 07:39 PM
Caidhlaoch's Avatar
Code 42 and 44
First off the car, 1992 Canaro RS 5.0 T5 manual TBI. I purchased this car not long ago, it ran great st first but then got more and more weird. Well while trying to dig out the gremlins, I found through the help of some folks here, it had the ECM from a late 80s S10 with a V6. So i found a replacement of the right kind and hooked it up. From the get go it is hard to start, and after a couple minutes of chugging it will finally idle pretty smoothly around 1000 rpms. Also with the "New" computer its throwing a code 42 and 44. I looked the codes up and 42 is a bad O2 sensor. Upon purchasing the car I did a full tune up and I put a new one on there. Not that it couldnt have gone bad of course. Just putting that out there. I also did some datalogging since I'm stumped. With both computers, especially the S10 computer, the O2 sensor values fluctuated alot. I'm not sure though if it's with range or not. So here's what I've got. Any guru's have any guidance for me? Also I attached datalogs from both ECMs the S10 computer 8062 and the proper ECM 8746.s
File Type: txt
File Type: txt
File Type: txt
Old Dec 24, 2019 | 08:21 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Re: Code 42 and 44
Do you have the correct PROM in the new ECM?
Old Dec 24, 2019 | 08:50 PM
Caidhlaoch's Avatar
Re: Code 42 and 44
In theory yes. It has the prom that came in it. I purchased it from a used parts seller, for what that is worth and it had a prom installed. It was listed as a used ECM from a 92 RS. And the part number is correct. Of course I assume the ECM and PROM are both correct and working properly in this situation.
unckybob
May 2, 2012 11:36 PM
autozoner
Sep 10, 2010 07:28 AM
smokingss
Dec 19, 2004 10:27 AM
Cooper
Oct 23, 2002 03:53 PM
zedder 1 9 9 0
Jul 4, 2001 06:38 PM
