Fuel pressure drops in 1 min
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Fuel pressure drops in 1 min
By design the TBI regulator does not hold pressure. It has a bleed hole drilled in the casting. Even if it has a TPI style pump with a check valve in the pump it will bleed off unless that passageway is plugged.
