FUEL INJECTOR SPRAYING WHEN JUST TURNING KEY
Old Feb 22, 2021 | 12:09 PM
help430924's Avatar
like the title says i have an 89 305 tbi camaro and the fuel passenger side fuel injector just sprays without trying to start the car, just turning the key on
Old Feb 22, 2021 | 01:10 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: FUEL INJECTOR SPRAYING WHEN JUST TURNING KEY
Could need new O rings
Old Feb 22, 2021 | 01:17 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
shorted to ground injector wire or shorted transistor in ECM could do that.
Old Feb 22, 2021 | 04:45 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Swap injector connectors and see if the problem follows the passenger side connector.
Old Feb 22, 2021 | 09:38 PM
Schurkey's Avatar
If it follows the harness, it's electrical. If the same injector still sprays, it's mechanical--stuck injector, failed O-ring.
Old Feb 23, 2021 | 12:27 PM
southbay08's Avatar
may need to be cleaned
onebadredz28
Oct 1, 2013 03:19 PM
Destructimus
Dec 26, 2008 12:23 PM
gstarnes55
Alternative Port EFI Intakes
May 29, 2007 09:31 AM
