305 TBI Fuel Pump
Old Dec 3, 2021 | 09:32 AM
Augern's Avatar
305 TBI Fuel Pump
I am having trouble with starting of a 88 TBI 305. If I turn the ignition on the fuel pump does not turn on. I need to turn over the car 3 to 4 times then I will finally hear the fuel pump run with the ignition on. The car will immediately fire then. The car runs fine after it is started. I have measured fuel pressure and there is no pressure until I hear the pump after the turning the car over several times. How does the fuel pump relay control the pump starting and does the pump need oil pressure to start?
Old Dec 3, 2021 | 10:04 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 305 TBI Fuel Pump
You do not need oil pressure for the pump to turn on but the oil pressure switch is in the circuit incase your relay fails (I'm guessing while driving?)
Does your pump only turn on once your oil pressure has built up?
You could have a faulty relay or relay circuit. Pretty easy to test with a test light. And a small jumper.
http://austinthirdgen.org/mkportal/modules/contents/images/Fig35_1988_5_0L_throttle_body_fuel_injection_engine_wiring.gif
Old Dec 3, 2021 | 10:41 AM
Augern's Avatar
I have tried just cycling my ignition on repeatedly without turning the engine over and the fuel pump does not run. It only will run after turning the engine over. I'll check the fuel pump relay but that sounds like it might be it. Thanks
Old Dec 4, 2021 | 09:44 PM
Schurkey's Avatar
Agreed. Classic symptoms of a failed relay, OR the relay wire harness, OR the part of the ECM that controls the relay.
The "usual" issue is a failed relay, or loose contacts in the electrical panel that the relay plugs into.
dennine3003
Nov 10, 2005 12:26 AM
iceman02
Sep 28, 2005 03:58 PM
paul5.0
Sep 6, 2003 01:38 PM
tzweelz
Oct 4, 2002 09:00 AM
kevin-design
Feb 27, 2002 02:57 PM
