Some new pictures of my TBI'd machine
Old Jan 19, 2002 | 03:58 AM
JPrevost's Avatar
Car: 91 Red Sled
Open element installed with no spacer ring, just needed some pounding with a hammer to clear the IAC and TPS sensors, that's IT. Also notice the hood underbracing had to be cut. All this because I'm using the RPM intake with the 1" adpator plate!
The 2nd picture is of the old school heater hose setup. Notice no more heater valve switch crap. It's clean and works great! Instant heat, no need to turn the climate controls to heat/vent/defrost to get coolant to flow into the heatercore. Now it's always flowing and keeping me nice and toasty on demand.
The 3rd picture is my exhaust setup. I know I know... The bend is crap. What can I say, it was a day before inspection (didn't have a muffler) job that cost $18 for the pipe w/ bends and $30 for the muffler from Summit Racing. $8 for clamps and universal mount which I hacked up and that's what I get. Believe it or not but it flows very well and sounds just right for my taste.
Old Jan 19, 2002 | 04:03 AM
gettaway305's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
looks good!
What open element is that?
Old Jan 19, 2002 | 09:47 PM
JPrevost's Avatar
Car: 91 Red Sled
54 views and only 1 reply...hmm...oh well.
The air cleaner is the Summit no name $15 piece drop base. For $15 I wasn't worried about banging the crap out of it to fit around the IAC and TPS. I'm just really glad the throttle linkage clears without any modifications! That was my main worry because last thing I wanted was to go down the road peg the throttle and have it get stuck open. I would have only a few seconds to turn the car off to save my life/engine.
I have yet to clean my engine bay so this spring will be nothing but detailing and working on my launch. 13.5's at 102 would be nice.
Old Jan 19, 2002 | 10:06 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
2 Replies.
I've only told you about 20 times now that your car is cooler than a naked Eskimo sitting on top of his igloo at midnight.
One day, when I find the money, mine will be cooler than naked Eskimo sitting on top of his igloo at midnight drinkin' a grape Mr. Misty (my car's purple ).
AJ
Old Jan 19, 2002 | 10:12 PM
AJ_92RS's Avatar
BTW, please go to the post about the 670 Holley TB and answer my question.
Thanks,
AJ
Old Jan 19, 2002 | 11:36 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
J,
Who makes that STB? I need to stiffen up the car quite a bit if I wanna do some autocrossin' this summer
Old Jan 21, 2002 | 12:45 AM
JPrevost's Avatar
Car: 91 Red Sled
The STB is the edelbrock carb/tbi 3 point. It's an awesome piece. I installed it when I did my subframe connectors (Alston). I felt the difference right away and more so than when I went to the larger sway bars, springs, wonderbar, and bilstiens. So definatly do the SFCs before anything else!
Old Jan 21, 2002 | 06:19 AM
deadtrend1's Avatar
even without SFC's I felt the difference putting the STB on. Took me about a hour to install (dark and cold outside). I began doing onramps a tad faster than i used to, which is making me chew up my tires more. tehe
~Tim
Glowsock
Jul 24, 2025 03:15 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
chubsworth
Aug 26, 2015 02:34 AM
Jote4805
Aug 25, 2015 06:11 PM
