Max fuel pressure
Old Jan 20, 2002 | 08:17 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Max fuel pressure
Instead of buying larger injectors is it possiable to install a high pressure pump and a stiffer spring in the regulator. Doing this would give you more overall volume and a better spray pattern. I dont know what pressure a TBI uses but I think that it is about 15psi. If you can get it up to about 50psi you should not need a larger injector. I am thinking about this crap because I am in the process of bulding a 383 to replace my 305.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
