Vader, LT1 cam specs again please. :-)
Old Jan 22, 2002 | 10:37 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Vader,
I am sorry to have to ask you this. I've seen you post that chart on here many many times.
I just did a search and found a lot of places that you did post it, but they are now gone.
If you don't have the chart, then can you possibly give me the specs on one from a 96 z28 LT1?
Thank you very much,
AJ
Old Jan 22, 2002 | 11:36 AM
NTChrist's Avatar
THANK YOU.
I've been busting my hump, looking for the specs using the search engine.
Help, Vader!
BTW, are you the guy that just out-bidded me on the 96 LT1 cam on eBay?
Old Jan 22, 2002 | 12:13 PM
AJ_92RS's Avatar
WHO, ME?!!!
No. Not yet anyway. My ebay name is malibu-aj. I used to have a 80 Malibu when I registered at Ebay.
Anyway, better sharpen your pencil buddy!!!!!!!
AJ
Old Jan 22, 2002 | 05:38 PM
JPrevost's Avatar
Car: 91 Red Sled
96 LT1 Camaro 205/207 @ .050, .447/.459 w/1.5, .477/.490 w/ 1.6, 116.5LS
Hope this is what you want. I did a search and it worked for me
Old Jan 22, 2002 | 09:26 PM
AJ_92RS's Avatar
Yes it helped a lot. Thank you.
I did a search, found a few places that Vader had posted those charts, but they showed up as a red "X". Then when I copied the properties and pasted them into the address line, I kept getting the error that Internet Explorer gives when it can't open a page.
If you have the chart, please post it, or send it to me via email. I had in stored on my old computer, but I don't use it no more.
Thanks again Jon,
AJ
Old Jan 23, 2002 | 08:58 PM
Tallboy's Avatar
what springs do I need to get when i install an lt1 cam?
i am planning on using 87+ tpi heads
r the 87 carb heads the same?
Old Jan 24, 2002 | 12:03 AM
NTChrist's Avatar
As for the springs, you're going to need something with a little more pressure. As roller cams have severe valve closing angles, the valve tends to bounce off the seat (valve float) when slamming shut.
I bought a set of $42.00 K-Motion valve springs, and I'm hoping that that will be enough. They fit in the pockets, and they're stronger than stock. Should be good.
Old Jan 24, 2002 | 11:20 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
hey i bought the same k-motion valve springs k-700 42.99 in jegs.. they work just fine with an lt1 cam.
Old Jan 24, 2002 | 07:13 PM
Tallboy's Avatar
what kind of rockers r u using with them?
would they hold up 2.....1.6 ratio with LT1 cam?
do vortec heads have the same size stud as 3rd gen heads?
anybody have the specs of all the diff LT1 cams?
where there diff LT1 cams?
Old Jan 27, 2002 | 08:15 PM
NTChrist's Avatar
I'm using the stock rockers, and the valves have a bind height of 1.050 inches. Multiply the lift of the cam, to the ratio of the rocker (1.6), and if the number exceeds 1.050", then they won't work.
Just guessing, I think it should work fine, anyways.
Don't know about the vortec heads.
Yes, there are different specs for the LT1 cams, but nobody seems to have a complete list...
Old Jan 28, 2002 | 07:52 PM
Tallboy's Avatar
exceed meaning the number is higher or lower that the coil bind
i got .73
guess i need a dictionary
Old Jan 28, 2002 | 09:29 PM
bbtaz97's Avatar
Car: 91 RS
im using 1.52 rockers without a problem.. with those springs and an lt1 cam..
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
