Adjustable fuel pressure reg
Old Feb 26, 2024 | 06:29 PM
Klag1993's Avatar
So I am putting an adjustable fpr on my 305 and I heard it should be at the end of the system but the return line isn’t pressurized. Can I just install a double feed to my tbi and not have a return on the tbi but have it running off of my fpr? Would this be ok
Old Feb 29, 2024 | 11:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Adjustable fuel pressure reg
Any reason why you need an adjustable regulator on this set-up? I would not dead head the pump without a proper return.
Old Mar 4, 2024 | 05:51 PM
Klag1993's Avatar
what do you mean dead head?
Old Mar 5, 2024 | 07:34 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
As long as you have some form of return line in your set-up you'll be fine. By dead head I mean nowhere for the excess fuel to go (return line), its just builds in the main line and makes the fuel pump work harder.
Old Mar 7, 2024 | 01:01 AM
Schurkey's Avatar
WHY do you need an aftermarket fuel pressure regulator? What's wrong with the one you already have, built-into the TBI unit?
Old Mar 7, 2024 | 06:38 PM
Klag1993's Avatar
yeah I have the stock return line on the back of tbi
Old Mar 7, 2024 | 06:39 PM
Klag1993's Avatar
also the stock one in the tbi
can I just remove it and put a block plate ??
ralbon
Dec 4, 2012 10:24 PM
Sttn89
Mar 1, 2012 11:08 PM
Gallileo60
Apr 15, 2007 07:21 PM
del91_305
Sep 26, 2003 09:39 PM
scauffiel
Nov 19, 2000 09:59 AM
