CFI inlet manifold
Old May 4, 2024 | 04:02 AM
UK1992RS's Avatar
CFI inlet manifold
I have the chance to buy an 88 305 motor which had the TPI set up, my car is a 1982 indy 500 and i want to keep it stock
My question is will the CFI inlet fit the later heads, Please note i live in the UK and we don't have an endless supply of used parts for american motors here
Old May 4, 2024 | 07:19 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: CFI inlet manifold
The angles of the center intake mounting holes will be at a different angle. You can use a die grinder to wallow the intake out a little to get it to line up. Otherwise, should match up.
Old May 4, 2024 | 07:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Trouble is bolts under manifold lid are exposed to vacume and likely difficult to seal properly long term when they are not screwed down to a flat surface,One possibility I had thought of when I was thinking about trying #193 heads on a CFI was to drill out and tap the center holes for 1/4" pipe plugs,install the plugs,then locate holes and drill and tap the plugs for the 3/8-16 manifold bolts
Old May 5, 2024 | 01:00 AM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
I'm posting this to demonstrate that it may be an accepted practice to elongate the holes as this intake already comes that way. I wish they had a better picture of this Weiand 90748 showing the actual bevel on the spacer.
Mirror Image
Sep 7, 2019 01:00 PM
LDR
Jan 20, 2017 07:10 AM
zacharyhorn
Apr 2, 2010 11:13 AM
jshepit
Jun 19, 2009 12:11 PM
