EGR Stuck?
Old Mar 16, 2025 | 05:42 PM
Smykster's Avatar
Car: 1991 RS 305TBI
EGR Stuck?
I've been chasing a rough idling issue and I'm inspecting my EGR valve on my 91 tbi. Should I be able to press the EGR closed by pushing on the diaphragm with the engine off? If I try to push on the diaphragm through the EGR "window", it will not budge at all.
Old Mar 17, 2025 | 08:34 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: EGR Stuck?
Yes, you can typically move them by hand. If you have a vacuum pump, you could also try to move it with that.
Old Mar 17, 2025 | 08:37 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR Stuck?
not sure how your pressing. You can only push up to open the valve.
Old Mar 17, 2025 | 11:56 AM
BURD's Avatar
Re: EGR Stuck?
Disconnect it. Who has those still on their cars.
Old Mar 20, 2025 | 03:28 AM
Schurkey's Avatar
Re: EGR Stuck?
No. You could lift up on the diaphragm from underneath to OPEN it, though.
If it's seized, it's defective. Usually the diaphragm leaks, but they can fail in other ways.
Everyone who can't remove EGR from the computer tune.
Disable the EGR, don't remove it from the computer tune = nothing but problems with detonation and fueling.
EGR isn't evil. No reason to disable it.
kallark
Aug 27, 2011 09:03 AM
DirtyracingGTA
Apr 2, 2008 11:55 PM
