Tbi injectors won't pulse
Hey, so I have a '92 camaro rs 305 tbi injection and my injectors won't pulse. I've changed the distributor, changed the injectors about a year ago, its getting gas, its getting spark, and it will crank, just no start. Im really confused on what to do, I've tried to check the ground wires but I cant find them for the life of me, I've checked the every fuse on the car, they are all good. I heard that it could be a faulty ecm but I hope not because those are a little pricey for me atm.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tbi injectors won't pulse
Any injector pulse if you pull the ecms prom ?
Engine: Lb9
Transmission: M20
It forces the 1228746 ecm into limp home mode as well as a temporary way to check vats by bypassing it.
2. Do you have power to the injectors when the ignition is "on"?
3. Connect a TBI 'Noid light to the injector wire harness. Crank engine. Does the 'Noid light flash?
4. Do the injectors click (and spray, IF there's fuel pressure) when you put a new 9-volt battery on the terminals? The injector terminals are nicely-spaced for testing with the 9-volt battery. Don't hold the 9-volt on the injectors--just touch and remove.
Injectors can fail to spray fuel because:
There's no fuel pressure
There's no power to the injector coil
There's no ground to the injector coil
The injector is varnished, the pintle won't move
The injector coil is open, no current flow = no magnetism to move the pintle
I had one varnished injector on my '88 K1500 5.7L. About the time I was wondering what I was going to do about it...it freed-up and has been fine for all these years since then.
You can verify the RPM signal to the computer by connecting a scan tool. See if the scan tool shows RPM when cranking.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
That I don't know. I was just wondering if it was possible that he could watch for movement of the tach if he didn't have a scan tool.
Thinking about it again, probably not. People swap these cars from fuel injection to carb all the time and the factory tach still works without a computer installed.
Engine: Lb9
Transmission: M20
Tach signal comes from the coil, icm sends a reference signal to the ecm that is a tach signal purple/white wire at icm.
Anyone performing D-I-Y work on a computer-controlled vehicle needs a scan tool, or scan tool emulator.
Trying to diagnose computer problems with no reasonable way to communicate with the computer to access the data stream and to have some bi-directional control is two steps away from hopeless. Instrument cluster "Blinky-Light" diagnosis is one step away from hopeless.
Yeah, it's much easier if you at least have a Snap-on MT2500. They are cheap enough now days.
