your 1/4 mile times
Old Jan 27, 2002 | 06:27 PM
89formula4life's Avatar
your 1/4 mile times
I want to know everyones 1/4 mile times and what mods you have on your TBI cars.... who has the fastest TBI on this board?? (this could get interesting! )
PS- good ETs or bad ETs--->tell even if it is a bad..
Old Jan 27, 2002 | 06:39 PM
mattRS's Avatar
ok, mines kinda confusing:have 2 main tracks here:ennis(1/4), and denton(crappy 1/8). when i was bone stock i ran a 10.9@63 in the 1/8at ennis and a 16.835@80 in the 1/4. stock i ran a 11.67 at denton. so there is about a second difference between how good the tracks are. now, i am running a 10.3 at denton, so im thinking a 9.4 or so in 1/8 at ennis, and maybe a 15.7 in the 1/4
Old Jan 27, 2002 | 06:42 PM
mattRS's Avatar
this is with 3" pipes catback, dump, crossflow(but dumped so is kinda pointless), K&N, ghetto ram air, new fuel filter, 160 stat. just put on a B&M shift kit, manual fan switch, coil, cap, rotor, and real ram air, so we'll see if it changes any next time i go to the track..oh, this is a 305 TBI ,700-R4 with 2.73s
Old Jan 27, 2002 | 07:58 PM
come on all give up your times!!!
Old Jan 27, 2002 | 08:10 PM
NJ SPEEDER's Avatar
14.209 @ 95.46mph
that was with posi w/3.54 gears(dana44 rear), spohn rear suspension(all rod ends), 2000 stal convertor and shift kit, edelbrock performer heads(60cc chamber, 2.02/1.60 valves), 1.6 rockers, edelbrock performer tbi intake, edelbrock headers(1 5/8 primaries/3inch collectors), !CAT, 3inch cat back, ultimate tbi, 350 injectors, adjustable regulator, stock cam, and stock chip.
i have since added a LT1 cam, switched to a holley tbi intake, holley 670cfm tb, a shortened exhaust system, battery to be relocated, and i will have a spool and 4.09's in the rear before igo back to the track. the car has also lost a lot fo weight, previous weight was 3280 with me and gas in it, should be closer to 3100 now. jprevost is also gonan be doing a chip for me as soon as i can get some data logging done.expecting to be around 300hp at the wheels adn run in the low 12.9's or 12.8's at around 105mph. we will find out about that on march 2nd when e-town opens
later
tim
Old Jan 27, 2002 | 08:24 PM
NJ Speedster, that is serious power coming off the old lo3..
that is wicked that you just didn't swap to a 350 like a lot of people do to race with---->keep up the good work on that lo3 :hail:
its good to hear of that little engine doing so well at the track..
PS-good luck on the strip
Old Jan 27, 2002 | 11:51 PM
91rsrider's Avatar
in the sig :lala: :rockon:
Old Jan 28, 2002 | 12:22 AM
JPrevost's Avatar
Car: 91 Red Sled
also in sig, but I have a 350 with vortec heads and a crappy cam
doesn't really count except that I'm using the GM ecm and TBI.
Old Jan 28, 2002 | 12:30 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
90 RS convertible here. Spent the day at the track Saturday: 60' 2.394, 1/8 mi 9.880 @72.18, 1/4 mi 15.276 @ 91.12. Mod's in my Readers Ride Page which still shows my prior best time at the same track last October (California Speedway in Fontana, CA). Lon
https://www.thirdgen.org/rides/index...ew&rideid=5460
Old Jan 28, 2002 | 07:55 AM
9177's Avatar
16.4@84mph K&N filter open element, Catco cat, MSD 6A, I posibbly have TPI heads but not sure. Auto tranny everything else stock.
Old Jan 28, 2002 | 08:57 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
I went 15.05 at 91 mph. THat was with headers 3 inch exhaust, edelbrock intake and pulleys.
Old Jan 28, 2002 | 10:16 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
13.18 at 102.52 MPH when i had my stock cammed and stock head LO3
Old Jan 28, 2002 | 04:44 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Originally posted by NJ SPEEDER
14.209 @ 95.46mph
later
tim
What's your gas mileage like? Decent enough for an everyday driver? I want to run low 13s or even high 12s but still have a good everyday car to drive around.
Old Jan 28, 2002 | 05:37 PM
JPrevost's Avatar
Car: 91 Red Sled
I don't know what Tim's milage was like but let me point out that he would drive his RS on the streets with uncorked Borla cat-back and slicks w/ skinnies. The guy had only one seat, for him! and the rest of the car setup for the strip, not as a daily driver.
The car was running really rich because he had the fuel pressure reg turned up so he didn't loose any horsepower beyond 3000rpm! So I'm guessing when I say city was like 10 and highway was probably around 15.
Old Jan 28, 2002 | 05:50 PM
Ezey Go's Avatar
16.1 at 86mph.At the time I had headers,flowmaster exhaust,b&m shift kit and under drive pulleys.I should have new times in about a month.
Old Jan 28, 2002 | 06:58 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ll
ll
ll
V
Old Jan 28, 2002 | 09:27 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
16.182 @83.8 with mods in sig.
I can make some excuses for not bein in the 15's, but I'll get there soon enough
:lala:
Old Jan 29, 2002 | 01:46 PM
OUCH!
What are you getting with that 350TBI cause that's another of my opitions.
As for 1/4 mile ETs, I've never had mine on a 1/4 mile but I can keep a carlength on a Mustang that is running 14.5s somehow.
My RS is quicker than any other RS I've ever driven or rode in. I guess whoever had it before me did some stuff to it. My intake manifold doesn't really look stock, it doesn't have the firing order on it like the other ones I've seen......
Old Jan 29, 2002 | 03:57 PM
CODY BEHNKE's Avatar
1991 Formula 5-Speed TBI 49,000 miles
14.89
Dual snorkel H.O. air cleaner w/K&N
Hypertech chip
Hypertech Pullies
Holley ignition module
MSD coil, cap, rotor and wires
AC rapidfires
Larger y-pipe
Cat Co cat
Dynomax cat-back
Firestone Firehawk SZ50ep tires
That time was with the stock 3.08 open diff rear
(Couldn't hook at all)
Was planning on putting in 3.42's with limited slip which should have put me around a 14.5 or so.
Old Jan 29, 2002 | 05:47 PM
NJ SPEEDER's Avatar
city mileage was bad because i am way too easily encouraged to show off, even if thge chick is ugly(hey, she may have a cute friend). my highway mileage was around 23 with the stock cam and that was with a dead torque convertor lockup, could have been aroudn 25 or 26 prolly if that had worked.
dunno wht the mileage is with the new set up yet. i'll know more about that soon though.
and jon, both front seats are back in wanna go for a ride?
later
tim
Old Jan 29, 2002 | 07:09 PM
BahamutRS's Avatar
When I ran her stock, she went a best of 16.8. I could never run her will all my mods in though...track closed :P
Old Jan 30, 2002 | 12:54 PM
BlackBird305's Avatar
hey tim i thought i had 1st dibs on a ride ...anyway to answer your questions 15.6 @ 89mph w/a 2.18 60' and i was still having some tunning issues w/the fuel pressure at the time....mods were...hedman headers 1 5/8 primaries, 3" flowmaster cat-back, ultimate TBI mods, 160 stat, hypertech chip, AFPR, torsen posi w/3.73's and removed rear seats....bought tim's old performer manifold which should be on this weekend...also eliminating the cat, and tim practiced his welding skills by boxing a set of LCA which will be put on w/spohn relocation brackets...with that and a set of drag radials im hoping to jump into the high 14's...who knows
Old Jan 30, 2002 | 11:37 PM
88 Camaro SC's Avatar
Car: 99 Trans Am
Oops, dont have times in sig But yeah, best time is 17.118@79. That was in BIG heat and before I added my thermostat and cooling fan switch. Gimme cool weather and i'l lbreak into the 16s guaranteed....
Nate
Old Jan 31, 2002 | 12:03 AM
Keith5's Avatar
Car: C1500
About the best my Formula has run so far is 17.2@78mph. Corrected for sea level that comes out to about 16.9. Plus that stupid track is uphill, I hate that.
This summer my car should go faster
Old Jan 31, 2002 | 12:44 AM
InDa12's's Avatar
15.32 1/4 mile
baytown
1989 350(tbi)
port*polished
pullies
open air element k&n
headman headers
Dynomax true dual exhaust
dumped the cat.
dumped the smog
bypassed egr.
hypertech chip
700r4
2.73 rear
265 goodyears
should of been quicker
the damn **** didnt hook up.
maybe i should run 20psi. next time
Old Jan 31, 2002 | 12:40 PM
NXS055's Avatar
FOREVER!!!!!!!!:rockon:
nah, I havn't been to the track yet... and probably won't until I do something to my car, right now its bone stock... I just can't stand the letdown.... hahaha
anyway, i'm lookin at an LT1 right now, so maybe she'll be scooter pootin down the track by the end of the year....
Old Jan 31, 2002 | 02:15 PM
deadtrend1's Avatar
i wish readers rides could be updated so i can put this in there.
Ok, with a big freaking subbox in the back, everything stock except pulleys, cheap open element, and the stock 3.08 open differential.
60 foot was 2.463.
1/8 10.544 @ 66.98
1/4 16.463 @ 82.29
I have Camaroracer1992's headers sitting in my garage awaing some minor Emission tube pluging (welding them shut), and then a 3 inch cat back with a high flow cat. I wanna go back and get timed again, then get my posi and gears and see how much better ill be after those too.
~Tim
Old Jan 31, 2002 | 05:08 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
15.501 @87mph in my 4400 lb, TBI Caprice
street tires, stock converter, 1st day out
Old Jan 31, 2002 | 10:52 PM
Crack Monkey's Avatar
times
16.3 in my '89 Caprice.
LO5 motor, air cleaner lid flipped. Otherwise stock (3.43 rear, open diff, M+S tires). No prep, just hopped in and ran.
Old Feb 1, 2002 | 02:10 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
My best to date (and I will make an excuse ) is 16.99@ 81.8mph.
My excuse; I first ran my car when I bought it in April 2000 with 165K miles just to get a baseline run. No mods at all. The best was 17.09.
Then I added the Dynomax cat-back, and K&N filter and went again hoping for a lot more. That's when I ran a 16.99. But my car kept shifting at 3500RPM??? Even if I held it out, it would fall on it's face after 3500RPM.
About 2 days later I found out the throttle cable was all screwed up. It cut it's way thru the housing. Got it fixed and ain't been to the track since. And I've done a few other mods since then to.
So needless to say, I AM VERY ANXIOUS TO GO!!!!!
And to all of you running sub 15's on a 305 :hail:
AJ
Old Feb 1, 2002 | 10:43 AM
FRMULA's Avatar
Best ET 12.4X at 105 with a 1.75 60'
Best consistant 60' of 1.61 with Nitto Drag Radials and the fat 245/60s still in front.
Have not done much tuning with the engine yet except playing with fuel pressure.
Will hit the track this spring with slicks and front runners. Looking for mid 11s N/A and hopefully 10s on the Gun...
350 with Holley Projection:
List of Mods:
South side Machine Subframe connectors and lift bars
3.73 Posi. Upgrading to Ford 9" with 3.70s for street 4.11s for strip
Lakewood 50/50 shocks and 70/30 struts. (might try 90/10s)
Mufflex 4" collector with off road y pipe
Hooker 1 3/4" Super Comp Headers
BE Cool Alum. Radiator
TH700 beefed, w/ TCI Super Street Fighter Converter.
I could go on but that would be way too much info...
Motor "STOCK"
Heads "STOCK"
Cam "STOCK"
Old Feb 6, 2002 | 09:35 AM
FRMULA's Avatar
ttt
Old Feb 6, 2002 | 01:04 PM
Rob -Formula-'s Avatar
I just recently got a g-tech and was really impressed with my cars performance. I know the g-tech is acurrate cause my friend ran it with his 69 camaro and it was within a tenth of his track time. My car runs high 14's at it's best. My best time was a 14.85@96mph. My mods should be listed in the signiture. If they don't appear i'll repost em. Tip for all you guys! Don't let the tranny shift for ya if you've got an auto. My best time this way was like mid 15s. Shifting manually to just before redline in 1st 2nd and 3rd gave me the best results (14s). Im now looking into camming this bad boy up. Oh, and my car has about 180,000 miles on it so no excuses for all you slow bastards.
Old Feb 6, 2002 | 09:11 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Best Time: 13.8
Best Trap: 102mph
60' 2.195
Rear: Stock 3.07
Trans: 4+3
Tires: RE-71 @ 35psi
Mods:
2" TBI units with 66# injectors
Port-Matched and Extrude Hone Xfire Manifold
Lidspacer
Injector Tower Spacers
CompCams Extreme Marine Hyd Roller/Full Roller valvetrain
TFS 23d heads
TPIS 1.75" Primary Coated Headers
Full Exhaust including Random Tech Cat/Flowmasters
7747 ECM with self-programmed chip
Stock Block and pistons
MSD Ignition and Accel Coil/HEI module
Taylor wires
K&N filter
Old Feb 7, 2002 | 08:51 AM
TBIWorks's Avatar
15.89@87.5mph, but that was with 2.73 open diff. With my 3.23 posi, I hope to low 15's.(I have a cam)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
