2 easy questions (wiring)
Old Jan 28, 2002 | 11:55 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I'm swapping in a new engine and need to connect a few more wires. I don't remember exactly where they go. I'm using my existing TBI harness.
1) Where are the 2 connectors that go to the coil? In the Chiltons manual it says that one has a pink and a white wire and the other has a black and a pink wire. I found one that was independant from the harness and has a connector on each side; is the other one in the harness, and if so, which side?
2) Looking at the harness at the back of the engine, I can see 3 2-wire grounds. Do these attach on the back of the cylinder heads?
Any information would be greatly appreciated. Thanks.
Old Jan 29, 2002 | 06:27 AM
firbird's Avatar
well the wires should go on only one way, i cannot remember good but one goes on first and the other slids on top of the ohter one,
and yes those go into the back of the heads, along with a big braided wire that goes into your firewall,
Jorlain
Aug 24, 2022 05:11 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
