TBI to 4bbl adapter
Old Jan 29, 2002 | 08:50 PM
Dan94GT's Avatar
TBI to 4bbl adapter
Does anyone make a product like this. Who does and how much? Id like to buy one because this intake looks like it sucks pretty bad and its heavy cast iron.
Old Jan 29, 2002 | 09:08 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
HLY-17-45 Holley Summit Holley Squarebore - tbi adaptor 43.69
Err... we'll see how that lines up.
Old Jan 29, 2002 | 10:11 PM
Tas's Avatar
Tas
www.turbocity.com has some too. If you're the do it yourself type, you might try to make one out of a cheaper 2barrel carb to 4 barrel intake adapter found any any auto part store
Old Jan 29, 2002 | 11:15 PM
mattRS's Avatar
how would one pull that off? the 2 bbl-4 bbl adapter
Old Jan 29, 2002 | 11:22 PM
Tas's Avatar
Tas
drill and tap holes to hold down the TBI on it, widen the opening with a dremel or other grinder you can get ahold of. If you're not comfortable tapping (its not that hard) you can drill holes to hold down the tbi with a nut and bolt. Be care ful not to let a nut or bolt fall in the engine. Maybe have the bolt superglued on the adapter upside down so it won't fall in and you only tighten the nut from the topside.
Old Jan 30, 2002 | 09:19 AM
Dan94GT's Avatar
Will the bores (tb) be in the right place to get 2 (of the 3) bolts in. are the bores the same size or will they have to be modified? i have seen some spacers that are open almost completely between the 2 bores is this necessary or will the 2 round bores( in the spacer) do.
db057
Jan 10, 2020 08:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
BLK87Z
Sep 18, 2015 11:29 PM
romcjr
Sep 17, 2015 05:18 PM
