o2 header hookup
Old Jan 29, 2002 | 09:18 PM
InDa12's's Avatar
o2 header hookup
i went and got the 02 sensor hookedup to my headers and my check engine is still on. on the back of my tbi unit theres a vacuum connection i put a bypass cap on it i dont know where its suppose to connect please help me on this trouble.
thanx
Old Jan 29, 2002 | 10:09 PM
Tas's Avatar
Tas
I caped the one in front of the tbi. I don't think you should cap the one in the back of the TBI
Old Jan 29, 2002 | 10:11 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
what error code are you getting?
-=-Mike
Old Jan 30, 2002 | 12:11 AM
InDa12's's Avatar
help with the b*llSh!t
okay i put the hoses on the front of the tbi but the back is where i dont know what to do.
does anyone know where the vacuum hose connects to, that is on the center of the tbi unit.
also when i hook my map up it starts crappin out on me.
does the map sensor hookup to the egr valve?
what does the egr hookup to.
man this is getting on my nerves.
please help me on all these questions that boggle my mind!!!
thanx
Old Jan 30, 2002 | 12:23 AM
Tas's Avatar
Tas
the hose on the front of the TBI goes to the stock air cleaner. I have an open element so I stuck a bolt in the tube to cap it. Maybe the thing you have in front should be in back?
Old Jan 30, 2002 | 12:05 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
THe vacum hose in the back of the throttle body is for the MAP sensor. THat is why it is running like crap too. Hook it up and it should be ok. THe map sensor is located on the passenger side hanging down off the cowl. there should be a vacum hose coming out of it as well.
Old Jan 30, 2002 | 01:06 PM
FRMULA's Avatar
Yup, vacuum port on rear of TB is for MAP. Actually it COULD connect to the front port but that would look sloppy. MAP sensor doesn't care as long as it has vacuum. It could even connect to the intake manifold.
How can you guys work on your cars without a Chilton's or a service manual? The vacuum and wiring diagrams alone are worth the expense. BTW there should be a sticker under the hood with a vacuum diagram printed on it too.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
