what is egr?
Old Feb 4, 2002 | 07:35 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
what is egr?
If i switch to the vortec heads with say a edelbrock performer intaker designed for the vortec heads but it had no erg what woudl this do ? would the car run?could i just plug it up?
Old Feb 4, 2002 | 07:50 PM
Tallboy's Avatar
your car will run
i just did the plug thing a while,car stilll runs
u will get a code sometimes thats all
and your water temp while cruising may be a hair higher
anybody reading this know what the casting number is on the quick ratio steering boxes?
or have a link to an article with it?????????
did they have the quick ratio box in 82?
friend says he has one from an 82...........
Old Feb 4, 2002 | 08:57 PM
5.0 10's Avatar
Whenever the computer commands the EGR, exhaust gases are routed back into the engine to lower combustion temperatures witch reduced detonation so the computer can advance the timing a little more. If you remove your EGR and plug your vacuum lines the engine will run like normal but you will get a check engine light whenever the computer commands the EGR, though. When the computer commands the EGR it moniters some other things to check and see if the valve is actually opening. If it doesn't open or isn't there at all the computer will know and give you an SES light and not advance the timing. So you will actually lose a bit of power if you remove the EGR because your timing wont be adanced more.
Old Feb 4, 2002 | 09:18 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Yes it will run without the EGR. If you want it done right then you need to make a PROM with the EGR spark advance table zeroed out, and the EGR VE table modifier set to 100%.
Otherwise it will advance the timing and lean out as well. That's bad.
Old Feb 5, 2002 | 07:28 PM
Tallboy's Avatar
why would it lean out?
anybody know the casting number(s)
on the quick ratio steering box?
did they have them in 82 z's?
yes yes
try the other board
and get lost in the 3000 posts....
Old Feb 5, 2002 | 07:41 PM
Tas's Avatar
Tas
because it would be getting more spark but not more fuel and fuel ladened exaust.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
