Cam/etc. plan - please critique.
Old Feb 5, 2002 | 12:23 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I'm scheming for my cam (and probably intake - Perf. TBI, if I can find one @ decent price) install over spring break in a couple months:
-LT1 cam (already bought off eBay)
-replacement pushrods
-valve springs (K-Motion K-700 - .500" lift, 1.265" diam., 125#)
-valve stem seals (can't decide between typical, umbrella, and the newer type w/Viton that a friend recommended, need to learn more)
-timing set (is there any need to replace more than just chain?)
Please comment, if you have any opinion/experience with this - am I wasting my money on a certain part? Forgetting something I should do?
Thx, JoelG
btw, I have an xtra set of rocker arms from the guy who sold me the cam, if anyone wants 'em...
Old Feb 5, 2002 | 12:45 AM
Tas's Avatar
Tas
I'd like you to try the 7547 weiand and be my guinea pig
Old Feb 5, 2002 | 02:13 AM
Car: 91 Formula
Engine: 305 TBI
I saw it in your sig - you don't have that thing on your engine yet?? I thought that thirdgen mechanical expertise was inversely proportional to the # of posts on this site, so it should only take you a few minutes to install the 7547!
Anywho, why did you go with that intake over say Perf. RPM, Holley, et al., if you don't mind my asking?
Old Feb 5, 2002 | 10:46 AM
Tas's Avatar
Tas
From what I've read and heard I think a dual pane carb intake will have bad fuel distribution. The holley TBI intake was/is known for fitment problems and I didn't want to deal with it. I liked the Edelbrock TBI intake but I wasn't going to pay $200 for it and I didn't find any used. My intake was $100. The inside of the 7547 is as wide as the TBI. You just have to grind the top squarebore ridge at the top for each bore. I liked that.
Old Feb 5, 2002 | 12:50 PM
Car: 91 Formula
Engine: 305 TBI
Hmmm, sounds like it's worth looking into.
What about the springs I mentioned above - anyone have a good/bad opinion of them? Anyone know where to get Viton seals (or if they're avail at all for SBCs)? Opinion on changing just chain or gears too?
Thx
Old Feb 5, 2002 | 04:56 PM
DM91RS's Avatar
Car: 91 RS
Thx
I'm running those springs with no prob yet.
I'd put the better seals on the valves . Are they going on the stock heads?
Old Feb 5, 2002 | 06:38 PM
Car: 91 Formula
Engine: 305 TBI
Yep, stock heads. I think I'll end up dropping a new engine in someday b/f I'd be able change out my heads; it's a little pricey for me now.
Old Feb 5, 2002 | 06:41 PM
Tas's Avatar
Tas
I think after NJ Speeder makes his run everyone is going to want heads :hail::lala:
Old Feb 5, 2002 | 08:44 PM
Tallboy's Avatar
and his gear ratio
is the weiand intake desinged for centerbolt heads?
its not big enough for a 350 tb?
anybody using a bigger tb on it?
wouldnt an adapter solve that prob?
Old Feb 5, 2002 | 08:50 PM
Tallboy's Avatar
and his gear ratio
damit double post,time for bed
u say u heard dual plane creates an air/fuel distrubution prob?
is that a typo?
i thought it was single plane at lower rpm's????????
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
