TBI question
Old Feb 5, 2002 | 06:02 PM
EROCK's Avatar
TBI question
I am interested in getting the aftermarket TBI from holley (pro jection) and wondered the difference in the 5.0 and the 5.7 one. THe 5.0 is more expensive. Does the 5.7 one have the 350 injectors? Don't ya think that one would be more expensive if so? Also I am going to put it on a regular manifold. Who makes a spacer for a TBI to carb intake with 2" bores? If anyone knows, can you please let me know. Thank you.
Eric
Old Feb 5, 2002 | 06:19 PM
Tas's Avatar
Tas
The injectors might be different. Call them. www.holley.com and www.turbocity.com have spacers.
Old Feb 5, 2002 | 07:27 PM
firbird's Avatar
i hate holley injectors, have they switched to gm yet?
Old Feb 5, 2002 | 07:40 PM
Tas's Avatar
Tas
I do believe so. You can also get a 670 used an use your injector pod on it.
Old Feb 6, 2002 | 04:19 PM
EROCK's Avatar
reasoning
Well, the reason I was asking was because I am getting the heads flowed right now and we are going to match the cam and intake for optimal performance. I am going to use a carb intake with an addapter then use the holley TBI with 350 injectors. I am sure that I will need them. So I will have to contact them. Just thought someone would know first. Thanks.
Eric
Old Feb 9, 2002 | 12:12 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Holly makes the carb to TBI adapter, not sure about the part # though. I'm probably just gonna make my own with some high temp plastic though.
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
