Is there a better way to clean Injectors?
Old Feb 6, 2002 | 05:38 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Is there a better way to clean the injectors on a TBI system other than pouring something in the tank? Can I pull them off the TB and flush them with something or is there a posability of damaging them by doing it this way?
Mark
Old Feb 6, 2002 | 07:14 PM
1sweet89rs's Avatar
dont bother
the injectors used in tbi's are self cleaning so a little bottle in the gas tank is more than enough.if you want you can get a can of carb cleaner and while the engine is running spray a little bit in there to clean the outside and top but dont go crazy,you dont need the outside tha clean
Old Feb 6, 2002 | 10:28 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Get the Chevron fuel injector cleaner and change your fuel filter before you dump the stuff in. It will dissolve most any deposit in your fuel system.
Old Feb 7, 2002 | 07:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Well... you could do what i did. Use an ultrasonic cleaner and some fuel system cleaner and pulse them for about 20 mins. I only had to do this b/c the preveous owner had the timing all fouled up and it backfired through the tbi for a while b/f i got it
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
