LT1 timing chain / gear
Old Feb 11, 2002 | 09:46 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Hey all, I got an LT1 cam and the guy was nice enough to send me the stock LT1 timing chain and gear from a 96 SS. It has 36k on it, and my stocker has 117k... will the LT1 chain go right on or will it not fit due to scary LT1 stuff that I probably dont understand?
Thanks (:
Old Feb 11, 2002 | 10:22 PM
Tas's Avatar
Tas
it will go on ( think) but its only a single roller chain. Since LT1 has a gear driven water pump, it can't run a true double roller timing chain like the Gen 1 small block chevys.
Old Feb 11, 2002 | 11:39 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Yea, Id like to have a double chain, but I figure that at best with heads/cam/intake (hopefully) I'll be mid 13s, so the lt1 set will be fine, and I'd imainge just about anything is better than the stocker which is about as loose as _______ (insert obscene comment here).
Thanks Taz! (:
Old Feb 12, 2002 | 12:11 PM
ChevalierSS's Avatar
Another Timing Chain/Gear Question
I'd like to install a gear drive system (I like the way they sound), but all of them I've look at say "not for use with OEM roller cams." Does anyone know why the wont work.
Eric
Old Feb 12, 2002 | 01:29 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
From what I have heard the gear drive makes the knock sensor think that the engine is detonating and retards the timing. Which makes the engine run retarded .
midge54
Dec 27, 2019 04:14 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
