? about putting TBI on a zz4 crate motor
Old Feb 12, 2002 | 11:01 AM
TBI305Camaro's Avatar
if i was to put a holley 670cfm TBI on a zz4 crate motor would the knock sensor, fan switch, and similar sensors that are on the block fit? also id need a new chip right? that way i can do away with the EGR, speed limiter, and plus the stock ECM wouldnt be able to put out the power for that kinda motor. im debating bewteen a carb or TBI so guys help me out. id also like to stick new heads, intake, cam in the 305 later down the road and put it in a s10 with n2o
Old Feb 14, 2002 | 08:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
bump ^
Old Feb 14, 2002 | 08:26 PM
firbird's Avatar
well first off you will need a new knock sensor for a 350 and the fan switch will still work but if you have not put a new one in yet you sould put one in that starts at a earlier temp, yea you will need a new chip or might as well switch a iron duke in there because it will not be too nice driving around. right now i am debating if i sould go to carb i cannt get this tbi stuff to work out as good as it sould i got too many various problems and just about every one that i have talked to have also had the thought of carb go through there head once or twice.
Old Feb 14, 2002 | 09:19 PM
thats what i was thinking i figured it would be rough since the ECM is made for a 305 with 170hp and not a 350 with 355hp ill probably go carb im still not sure either that or im gonna get a second car this summer...either a mustang or a l98 camaro im leaning towards the camaro but maybe a stang not sure yet only time will tell
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
