Anybody using Edelbrock 1207 open element?
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Everytime I walk into Auto Zone, I see it, and want it!!!! I just need to know if it will clear the TBI linkage and cruise without any spacers, and If I would need to go down to say a 14"x2". Any body suggest anything better? Thanks!!!
Car: 2002 TT Corvette
Engine: 5.7L
i dont think it will fit... 3 5/16 is a bit high. when i was looking for my open element (k&n w/ xtreme lid) i only got 2.5" high and barely was able to close the head. a 10" will fit with no problem.
Engine: 5.7L
if u go with a 3", can u use a tbi spacer on it? i got a 1.5" tbi spacer and the stud for the tbi is like hitting my hood...i mean going through the insulation or whatever. if it'll work, im gonna get one of those too.
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I have the Edelbrock 1207. It's a dropbase so you'll have to use the tbi spacer ring still but, everything clears fine. Also, you'll have to loosen and pivot back the coil bracket so the small coil wires won't rub on the edge of the air cleaner base. You'll see what I mean when you install it.
toronto formula
Sep 10, 2015 07:31 AM
