serpent belt routing w/o air pump?
Old Feb 23, 2002 | 11:24 PM
InDa12's's Avatar
i have the lo5 engine and i have been driving around for awhile. i have taken the stock exh. manifolds off and replaced them with some headman headers. i of course chopped the cat and every thing that has to do with emmisions, except o2, and other bullsh**.
the air pump isnt hooked up to any thing so its just taking drive power up. unless i can re route it to blow more air into the intake. hmmmm
well does any one have a diagram on the belt routing. or explain.
thanx
Old Feb 23, 2002 | 11:40 PM
JPrevost's Avatar
Car: 91 Red Sled
https://www.thirdgen.org/newdesign/tech/
Go down to Miscellaneous Modifications.
I don't want to just GIVE out the links considering they're on the tech articles page.
The smog pump doesn't take any power to turn, it's not like the 70's smog pumps. If there is a reason to remove it, it's because it's ugly and takes up space. It's also weight and we all know that the lighter the vehicle the faster.
As for routing the air into the intake, it won't work like a supercharger. It doesn't move enough air to even increase the flow of the intake at IDLE, let alone driving down the road or WOT.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
