What is the lbs. on the OEM injectors (5.0 TBI)
Old Mar 30, 2002 | 03:20 PM
89WS-6's Avatar
I need to know this. And where would be a good place to buy some upgraded versions with a higher lb. rate. My car is having problems. It is sputtering above 3500 rpm. And I am suspecting it is the injectors, but I can't be for sure. Maybe ya'll could help me on this too. Thanks,
Old Mar 30, 2002 | 03:35 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
mine does it above 4500 a slight bit.........and i have flow matched injectors and run an adjustable fpr at 16 psi.....im leaning towards the stock fuel pump tapping out...id talk to these guys they are pretty good with tbi applications where i got all my stuff
http://www.turbocity.com/Index.html
Old Mar 30, 2002 | 03:48 PM
89WS-6's Avatar
Thanks man, then is there something I can do to my fuel pump. Or how much is one to replace the OEM one. Not any better flow rate?
Old Apr 1, 2002 | 03:46 PM
EROCK's Avatar
The one made by holley is a better flowing one. It is just like the oem but higher performance. I put mine in and the car dropped .30 in hte 1/8! I have documentation of the times but unfortunatly I do not have a part number for the pump. If it helps I got it from Jegs. I am sure if you tell them the application, their tech guys can match ya up. Good luck
Eric
Old Apr 1, 2002 | 04:03 PM
wasp's Avatar
im gonna get this one
http://www.jdsperformance.com/index....d=76&fcmd=item
MustangBeater20
Oct 29, 2022 09:20 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Jote4805
Aug 25, 2015 06:11 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Randomtask2
Aug 13, 2015 01:57 AM
