Fuel Pressure Gauge installation
Old Apr 10, 2002 | 08:38 PM
Berlinetta's Avatar
ok guys, how do i do it and what parts do i need? Thanks a lot!
Old Apr 11, 2002 | 02:52 AM
Jza's Avatar
Jza
It's going to depend on the type of fuel pressure gauge you get. If it's a diagnostic FP gauge meant to be used for finding a fuel system problem, they usually require an adapter. This is going to depend on the make and model of the gauge you get. The Snap-On diagnostic FP gauge I use has a schrader valve adapter that threads in place of the fuel filter underneath the car. Others have the adapter thread in between the hard and soft lines near the power steering pump. You can also buy those adapters seperately and leave them there permenantly so you can use the FP gauge any time.
An instrument fuel pressure gauge that installs permenantly inside the car has either an isolator (for mechanical gauges) or a sender (for electrical gauges). You will have to find a way to install them somewhere in the feed line. Most people splice in a tee somewhere on the rubber section with hose-clamps or something, and for the low-pressure situation that TBIs have, this is fine. If you're a little more creative, you can get brass fittings/adapters at any hardware store and make up something that will thread inline at the point the rubber feed line connects to the hardline that goes to the TBI unit. This is a better idea if you plan to ever go to a high-pressure fuel system later (eg TPI) or just for a cleaner looking installation.
So depending on the make/model/type of gauge you get, you'll need at least some method of tapping into the pressurized fuel line, whether it's threaded in or cut and spliced into a rubber section.
Old Apr 11, 2002 | 11:12 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
What about that fuel pressure tester from Autozone? I think its called The ACRONIII. Do I just screw that thing either where the fuel filter is or where the hard and soft lines come together? Anyone know what gauge I am talkin about? Looks like this.
Old Apr 11, 2002 | 12:12 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
That guage is from somewhere else I think. $75 or so. It has an adapter that screws into the TBI and the hard fuel line screws into it. Then it has a proprietary T fitting for use with its hose. The AZ guage is supposedly functionally the same thing, but $50. I am going to check it out next chance I get
Old Apr 11, 2002 | 12:43 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
actron III
The actron 3 pictured above works great. I even took the clear bleed off tube off and mounted it inside my cowl hood permantly.
Works great.
Old Apr 11, 2002 | 12:57 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Ok, looks like I was wrong.....I just went to my local AZ and bought the Actron III - $40 + tax and a great deal, IMO. Plus you don't have to wait for shipping. I can't wait to try it out!
EDIT: this is the exact same piece that Actron will sell you directly, only they want $75+shipping!!!! What a joke!
http://www.actron.com/cgi-bin/web_st...17.htm&cart_id
Old Apr 11, 2002 | 06:09 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
religious people in texas might have a problem with your avatar jza, might wana talk to brad on the detailing forum
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
