MSD Installation???
Old Apr 14, 2002 | 08:37 PM
RS91's Avatar
MSD Installation???
Does any one have the wiring diagram of MSD 6A for chevy camaro that has Dual connector coil? I went to MSD site and downloaded the file but I was given two different set-up for It. I just need to know wich one.
First Diagram: Diagram shows connect the both pink wire from the coil and connect them on the orange wire from MSD. Connect both white wires from the coil and connect them on the black wire from the MSD.
Second Diagram: Diagram show only one pink wire is connected to orange wire from MSD. One White wire connect to black wire from MSD. And this one envolves wire connection to distributor while the other does not...
which one do I use...
thanks..
Old Apr 14, 2002 | 08:55 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
call msd tech tommorrow........i did when i installed mine, hell i called edelbrock when i was installing my intake.............dont be afraid to annoy people with lots of questions ......lord knows im not ..
Old Apr 14, 2002 | 09:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
can anyone tell me about the msd 6t. i saw it in a circle track catalogue and didnt know whtat the difference is between that and the 6a and 6al
Old Apr 15, 2002 | 07:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think the 6t has extra vibration damping for rough environments. The 6t also allows you to plug in a separate rev-limiter, using weatherproof connectors. You can't add a separate rev-limiter to the 6a... so you'd be better off with the 6AL. Plus, the 6AL comes with the anti-vibration mounts, which "adds" to the extra cost of the 6AL from the start. (No anti-vibe mounts with the 6a.)
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
