High Mileage engine Question within
Old Apr 14, 2002 | 07:07 PM
ORAY777's Avatar
My motor has about 144kmiles on er'. Runs pretty good. I'm thinkin about puttin a cam in er'. It's a 350. I'm just wonderin if this is a good idea or not such a good idea plus a few other bolt ons like headers, intake. How can you check the condition of your engine? She runs pretty good though. Give me some advice. Later.
1991 Z28 1LE 5.7 auto.
Old Apr 14, 2002 | 10:49 PM
berlinetta84's Avatar
you can start by thinking about how much oil it burns...it its more than about a quart every 3000 miles, dont go for anything. listen to the engine to see if lifters are going (dont confuse that with injectors. do a compression check to see how all the cylinders measure up. but anyway, with that many miles itd be best to either rebuild or get a crate. before performance parts can be added on, the rest of the motor has to be strong enough to support it. hope this helps a little
Old Apr 15, 2002 | 07:29 AM
jimbuck's Avatar
I have headers, runners, and converted to a 6 speed. Mine has 214K on it. Still runs good, uses no oil.
Old Apr 15, 2002 | 07:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If it seems strong, it probably is... And besides, with that many miles on your cam, the lobes are probably worn down- a stock cam might bring back some power! When I rebuild my motor, I'm going to check the lift at the pushrods- I think 230,000+ miles has worn my cam down to nothing.
Old Apr 15, 2002 | 08:19 PM
2vmodular's Avatar
not too much more effort to pull the engine while you have the exhaust manifolds & intake off anyways. pulling the engine from the bay would give a lot more clearance for camshaft swap too.
While you have the engine out anyways, check the internal clearances. May well have ridges on the cylinder walls, worn valve guides, worn rings, bearings, oil pump, etc. At the bare minimum, replace all the rubber seals in the engine.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
