what should i set my timing at?
Old Apr 15, 2002 | 07:57 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my friend just advanced his timing from 6BTDC to 10BTDC and said it made a huge difference. I set mine to 6BTDC but think i'll advance it more. Where should i set it? my plugs are 2 heat ranges colder than stock with compression only .2 higher than stock so that should curb any preignition/detonation unless i really advance it. i run at least 91 octane. rest of car's specs are in the sig.
Old Apr 15, 2002 | 08:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Go as far up as 12. Do it 2 degs at a time & see where it runs best.
Old Apr 15, 2002 | 08:34 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Thats a good queastion. I wanted to advance mine, but I don' t know what its set at now. I want to put my 100 jets in so I figure I'll have to retard it buy 3-4 deg. But I don't know what to start it.
When does detonation commenly occur in a 10:1 comp. motor?
Old Apr 15, 2002 | 08:56 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
too many variables involved..
can't be done guys.
Ambient temp, engine operating temp, cam design and mixture quality (there are about 1/2 dozen others-like drivetrain config and weight) all play a role. Regardless of how good someone says he is at tuning,, you can't do that on the internet.
now.. where U start:
Find out how much you are getting from the mechanical advance in the distributor. Shoot for about 36-37 total. If you have to and the motor has a little cam, give up some mechanical advance to allow a little more initial advance.
The sweetspot on most mild 350s is 8 to 12 degrees initial and a max of about 20 in the dist (most factory dists don't allow that much internally).
Old Apr 16, 2002 | 10:58 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
How do I find how much machanical advance I'm getting?
How do I find my initial timing?
Old Apr 16, 2002 | 05:44 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
two options - locate someone or buy a dial-advance t-light
they are about 50-60bucks but well worth it. You can also put a timing tape on the harmonic bal. but it is harder to read when the motor is pulling a few rpm.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
